Question about Vizio Televison & Video
Need to use ematic at103b remote to turn vizio smart tv on /off
    Master:
  • 665 Answers
Try reading the Manual:
https://www.manualslib.com/manual/691263/Ematic-At103b.html
Posted on Apr 23, 2019
  • Darrin P. De May Apr 23, 2019
    https://www.manualslib.com/manual/691263...
SOURCE:
dickandannet
  • 2548 Answers
SOURCE: I use to have a 70" Vizio smart tv but kids broke
You have to program the remote to the T V by feeding the model and type serial no. etc into the remote control
Posted on Nov 01, 2014
RALilja
  • 400 Answers
SOURCE: Have 2008 vizio smart tv-how do you program a new remote to the tv or tv to the remote?
Hello Mat,
Read the instruction manual that came with the remote as that has codes in it and the procedure to program the remote also. You can also look up the codes via the internet using the make and model of the remote. The listing will usually have all possible codes that might work with your Vizio tv, and you have to try them all until you find the 1 that works.
Good Luck!
Rich Lilja
Posted on Mar 26, 2015
AJIN G
  • 6694 Answers
SOURCE: How can I turn my vizio smart tv without a remote
check the links bellow .
http://electro-medical.blogspot.com/
https://www.youtube.com/watch?v=t40j4bPx6FY
Posted on Nov 20, 2015
  • 51832 Answers
SOURCE: I need to know how to program a ge universal remote to my vizio smart tv
Use code search to find something that will control some or all functions.
Posted on Oct 10, 2016
gopakumarg43
  • 76046 Answers
SOURCE: How to program a universal remote to ematic dvr at103b
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Posted on Dec 09, 2016
Is there a TV Guide for the ematic AT 103B digital converter box?
There is an electronic program guide. However, it's limited. To see the current program and upcoming programs for the current channel, press the EPG button on the original Ematic AT103B remote. (Universal remotes may or may not match the function.) To see the other channel's program list, use the left/right arrows to scroll through the lists for all of the available channels.
You may find a web site like Titan TV, http://www.titantv.com/ , more useful. The site has a guide to all channels at once by time for your area OTA channels.
I hope this helps.
Jul 29, 2018 | Televison & Video
Ematic AT103B manual
The manual is available from the manufacturer's support site: https://ematic.zendesk.com/hc/en-us/articles/220756147-AT103B . The direct link to the manual is currently https://ematic.zendesk.com/hc/en-us/article_attachments/208176947/AT103B_manual.pdf .
I hope this helps.
Feb 22, 2017 | Ematic Audio Players & Recorders
Is the Ematic AT103B Converter Box compatible with Suddenlink cable/digital service?
No, the Ematic AT103B is an over-the-air digital ATSC tuner and will also can convert the digital signal to analog NTSC for older TV tuners. It will not work with any cable service and is for "cord-cutters". The AT103B requires an antenna to receive your local OTA channels. Depending on where you live, you may get some channels with an indoor antenna. You will get better reception with an outdoor antenna. See http://www.tvfool.com or http://www.antennaweb.org for details on the channels you can receive with an antenna pointed in a particular direction.
The Ematic set top box does provide an HD signal output and a DVR (time-shift function) so it is more advanced than the first generation OTA converter boxes. The original (available with the government coupon) converter boxes only gave an SD output.
I hope this helps.
(antennaweb.org gives a very conservative list of available channels but assumes an external antenna. tvfool.com lists the channels that are likely to be received with a variety of antenna strengths. An antenna signal amplifier can improve the reception. (Digital stations will not be seen if the tuner can't lock onto the signal.) However, when the amplifier fails, you may find some channels will not be received at all.)
Dec 08, 2016 | Televison & Video
I have a GE universal remote I need remote code to program my ematic at103b
hi Tammy, The link below is a download for a GE universal remote control codes, You need to choose which model remote you have... CHEERS..
https://byjasco.com/support/ge-universal-remote-codes
Mar 30, 2016 | GE Televison & Video
Program my g.e remote control to a A.T.103 gematic digtal box
Tv Converter Box Deals
www.bestdeals.today/tv-converter-box
Digital Converter, Ematic Digital TV Converter Box with Recording, Playback, ...Digital to Analog TV Converter DTV Tuner Box w Remote, Program Guide, PLUS MORE! ... GE Television Antennas Omni TV Indoor Antenna 24731 ... HDMI/HDTV/DTV/RF/RCA/USB Digital Converter Box TV Tuner With Remote Control PVR.
Ematic DVR Recorder Television HDMI Media Player ...
www.altatac.com/p-15751-ematic-dvr-recorder-television-hdmi-media-p...
Ematic DVR Recorder Television HDMI Media Player Converter Box w/ USB ... TheEmatic AT103B Digital Converter box allows your TV without a digital ... Features an electronic program guide, parental controls, and a USB ... Full function remote controlincluded. .... My Account My Account Order Status Track Your Order.
At103b Ematic Converter Digital Atsc
antennadisht.com/at103b
11 ozmiscellaneouspackage contents converter box remote control 1 x user ... Review (mpn:at103b for sale) Digital Converter Atsc Ematic At103b Box . ... You can find your tracking number by ing on my and scrolling down to your purchase with us. ... Features an electronic program guide, parental controls, and a usb ...
Jan 24, 2016 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
