MY SINOTEC PLASMA IS STUCK ON USB MODE WHENEVER I SWITCH IT ON AND THE MENU IS NOT RESPONDING
I am pleased to tell you that I found the solution and my television is now working here in Zimabawe.
SOURCE:
  • 11967 Answers
SOURCE: My Lumix Panasonic DMC-TZ4 Digital
Try this...remove the card and battery...press every button....leave it alone for 20 minutes....insert the card and then the battery....turn it on.
Posted on Mar 08, 2011
gopakumarg43
  • 76046 Answers
SOURCE: My Sinotec MP-32KE63 is stuck on the USB mode. The remote control is broken.
Without a remote control, you can't unlock it. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the "brand name only" of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Mar 20, 2015
MrARCADIAN
  • 284 Answers
SOURCE: My sinotec plasma tv is stuck on standby mode,what could be the problem
could be a power issue, i would try to unplug the tv for 5 minutes and replug in and see if that helps, if not time for a visit to a TV repairman! if you can do it check the power supply board see if there any swelling on the caps. then might be time to replace the board or the caps.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Posted on Dec 16, 2015
AJIN G
  • 6694 Answers
SOURCE: Need codes for UNIVERSAL REMOTE for Sinotec TV Mocel ST-39KC70. Many thanks.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Posted on Jan 24, 2017
Testimonial: "Thanks Electro-Med. Going to try all answers from everyone. Yours looks very concise but long...am sure it works though! Thanks. Will let u know how it goes."
emissionwiz
  • 84625 Answers
SOURCE: My Sinotec TV is in USB mode, and I don't have a remote or universal remote. How do I get out of the USB mode?
You MUST have a remote.
Posted on Sep 04, 2018
How do i take USB mode off my sinotec tv without a remote?
At the back there a menu buttons or source press then go down using volume up or down use menu to select
Mar 03, 2017 | Televison & Video
Dec 15, 2015 | Televison & Video
My P50HDTV10A 50in. Plasma tv will power on using power button but is stuck with the menu on screen all the buttons on the side work remote won't work can't get it out of menu. Any suggestions .
To make it to factory reset, you have to enter its Service Mode option; and select Factory Reset [System reset].
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 25, 2014 | Vizio P50HDTV10A 50 in. Plasma HDTV
Sinotec 32inch plasma TV.I have no remote.it has only menu button ;v+/- buttons working.he can I switch it from USB to other functions?
If it is a universal remote control, just try to set it with an other code stated for Sinotec TV, in the remote controls' code list. Check all the codes said there, and choose one code, which give you maximum functionality with TV. That is all to do; and is the way too.
google.com/+GopakumarGopalan
Dec 18, 2013 | Televison & Video
I connected an usb device to my sinotec st-26kc42h and switched it to usb mode without an remote now its stuck there how can i reset
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 04, 2013 | Televison & Video
Lost my aim plasma remote control and it stucks on usb mode
use the manual button, go to the menu, and restart to the factory default adjustment.
God bless you
Oct 10, 2013 | Televison & Video
How do i get out of usb mode on my sinotec tv without a remote
You do not need a remote control. I used my smart phone with IR. Down load tv remote apps and wala its sorted.dont buy universal remote it did not work for me could not find the Sinotec that i have so wasted R400.00
Apr 20, 2012 | Televison & Video
I have a 42" samsung
Do you have aspect in the menu and can you change the format
Dec 06, 2010 | Televison & Video
Phillips plasma tv. Settings menu pops up all the
Philips.com should have a software upgrade for your TV to fix the problem. This is a common problem with Philips TVs and they have made upgrade software to address the problem.
Go to the Philips web site and all the procedures for download to your TV will be there. The only thing you will need to this is a USB memory stick. Download should be FREE.
Aug 03, 2009 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
