Question about Huawei Cell Phones
How can i solve the message receiving process on huawei nova lite 3
Transfer from P9 Lite Huawei recordings to my pc?
https://www.uscellular.com/uscellular/pdf/huawei-ascend-y-usb-transfer.pdf
Mar 04, 2018 | Huawei Cell Phones
Help me pls unlock my huawei p8 lite pls
I suggest you can approach Unlocking4u.com and specify the country,locked network of Huawei P8 Lite .Based on the availability you can get the permanent unlock service along with free instructions.
Feb 09, 2018 | Huawei Cell Phones
Why the Huawei S2700 switch cannot transparently transmit the packets whose VLANID is greater than 127 after VLAN translation is enabled?
Take the Huawei S2700-9TP-SI-AC for example:
After the VLAN translation function is enabled for the Huawei S2700 switch, the 128 module problem exists because the chip difference supports only 128 VLAN TO VLAN entries.
The packets received through the port are processed as the VLAN smaller than 128. The calculation method is (vlanid)%128.
Therefore, for a VLAN greater than 128, port vlan-mapping vlan id map-vlan id, that is, the mapping from the VLAN to the same VLAN, must be configured for the transparent transmission to be implemented.
More related:
Huawei S2700-9TP-EI-AC
Huawei S2700-9TP-EI-DC
Huawei S2700-9TP-PWR-EI
May 11, 2017 | Huawei Computers & Internet
How to delete text photo from gallery file on Huawei 8800 phone?
no root !
Can you retrieve deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery. Don't hesitate and recover deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now!
Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup. This video is showing you how to recover deleted sms messages on Android without root your phone.
Some common situations that lost text messages you can recover from:
1. accidentally deleted texts on your android phone
2. lost text messages after Android 5.0 updated or other Android upgrade.
3. save text messages from water damaged, crashed, broken or smashed Android phone
4. Android deleted text messages randomly by itself
5. Factory restore Android phone.
And more...
Watch this video and share it with your friends too so that they can also get their precious lost data back.
Apr 02, 2013 | Nokia C3 Cell Phone
Huawei won't send or recieve mms message
Try to turn it off and on. In the summer no was texting me until my phone died. Then I turned it back on and receive messages. If not that try to update your roaming capabilities or contact your provider.
Feb 21, 2013 | Huawei Cell Phones
Phone doesn't open. if turns on shows message: Boot loader A3.CC Err>A5,6935.2E Battery OK OK to Program Connect USB Data Cable it doesn't continue anywhere.
something seems to be wrong with your bootloader. what you need to do is
1. go to www.modmymoto.com and download the A3.CF bootloader which is the latest bootloader from motorola.
2. once you've done that, download the latest version of RSD Lite (you'll find it on google).
3. Install RSD Lite on your computer and open it up.
4. After the program recognises your phone, look for the bootloader that you downloaded and hit start. DON'T UNPLUG YOUR PHONE TILL THE ENTIRE PROCESS IS COMPLETE.
This should solve your problem.
This process can be risky, but it's the only way it'll work. For more information on installing the bootloader with RSD Lite, please read through the forums at www.modmymoto.com carefully.
Apr 06, 2009 | Motorola Mobility RAZR2 V8 Cellular Phone
Cell Phones Logo
35 people viewed this question
Top Huawei Cell Phones Experts
Phil Whisenant
Phil Whisenant
Kenneth Walker
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
