Question about Refrigerators
Have a glacio ice maker it is making ice at the element but they stay there and melt not tipping into container what could be wrong it is brand new
SOURCE:
lsteward68
  • 333 Answers
SOURCE: my ice maker is really
it could be 3 things.
1. The icemaker has a water filter. Has that ever been changed?
2. The water inlet solenoid maybe going bad.
3. The freezer is not freezing the ice. if this is the case clean the back and bottom of the unit as to allow airflow.
Posted on Apr 15, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Apr 27, 2009
  • 102 Answers
SOURCE: Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Posted on Aug 06, 2009
EllaWatson25
  • 725 Answers
SOURCE: Ice maker stopped making ice. I had to melt ice
Jim, you will need to replace the heating element and most likely once this has been replaced, your ice maker should work properly unless the ice broke another part on your ice maker.
I would start with the heating element first.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number and we will get the correct part out to you asap!
We look forward to getting your ice maker working properly again soon!
Thanks, Ella
Posted on Nov 09, 2009
  • 77 Answers
SOURCE: ice maker leaks water
Good work thus far. If the ice maker tray that holds the ice is leaking, you need to get a new ice maker. It would never work right if you tried to patch it, and would only cause further headaches. Sounds like you have a little experience which is good. Go down to a local retailer and purchase an ice maker and install it yourself instead of paying someone to do it ;) There is no foul in paying to get it done though. good luck!
Posted on May 30, 2010
My glacio ice maker is not working. Both lights for ice full and add water are on. Why?
There is a lever in the ice box. push it down, it is the cut off switch to stop making ice after it is full, it is stuck in the up position.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Jan 14, 2018 | Refrigerators
The top ice maker freezes up and the ice cubes don't dump
The heater in the ice tray is not going on to slightly melt the cubes so they can be pushed out of the tray. Either the element is burned out or it not receiving power. If it is the element you may have to replace the whole shebang since I have not seen the tray assembly sold separately. But I have seen brand new ice makers for about 45 dollars on ebay so ....................
Feb 29, 2016 | Refrigerators
Dce33a1bb ice maker makes ice but doesn't stay frozen
Poor draining of water in the ice bin will cause a high rate of ice melting, Remember this is not a freezer but an ice maker. If the machine is making ice OK but it is melting to fast then check to make sure the bin is draining all the melt off and not letting water stand in bin causing ice to melt fast.
Sep 05, 2014 | Scotsman DCE33PA1BC 15in Built-in...
Ice forms as large block not in cubes
Defrost thermostat is bad. Defrost element is staying on for too long raising up temperature causing ice to melt.
Mar 26, 2014 | Fisher and Paykel Active Smart E522B...
Ice maker not working
Is water getting into ice tray? If not, check the water line feeding unit. If that is ok then check the solenoid that controls water flow into tray.
If water is frozen in tray then anomaly is caused by the mechanics of ice maker. If the ice melt mechanism does work the ice will stay stuck in there. Caused by broken heater element in ice maker or a defective thermostat in ice maker that turns the heater element on. Or it could be a defective motor in the cam that sets up the sequence of events.
Easiest fix is to just replace entire unit from ebay for about 40 bucks.
Nov 22, 2013 | GE Refrigerators
Just contact us at:
Thanks, Ella
Nov 09, 2009 | GE Profile Arctica Stainless Steel Top...
Jun 19, 2009 | Scotsman DCE33PA1SC 15in Built-in...
The ice maker (GE Profile - 3 years old) produces ice and then, the next morning, the ice melts down into the rest of the freezer (i.e. the ice compartment is somehow not staying cold enough to sustain any...
If the unit is freezing well in the freezer and your ice bin is defrosting or ice is melting together it is your ice maker over filling the tray causing water to leak into the bin. You can purchase kits that contain all ice maker parts needed , it may be the ice maker and it may be the water inlet valve in the back , both come in the kit , go to sears parts on line with the model number from your unit.
Dec 30, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
