Question about The Computers & Internet
MY I VIEW 13.3 INCH CONVERTIBLE WILL NOT COME OO. AT THE BOTTOM OF THE SCREEN IT SAYS PREPARING AUTONATIC FIX THEN SHUTS DOWN
    Top Expert:
  • The Master
  • 63,072 Answers
PERHAPS IT IS PAST DUE TO BE REPLACED .
Posted on Apr 25, 2019
4 Suggested Answers
SOURCE:
  • 3940 Answers
SOURCE: Have just been given 50
There was a reason it was free.
You can check with a TV repair service, but it will likely be cheaper to buy a new one than fix this one.
Posted on Jun 14, 2008
erone47
  • 458 Answers
SOURCE: laptop stuck at Preparing to Standby
Your Operating System is corrupted.
You need to repair it by performing a repair using your Opareating System (OS) installation CD.
If you are using Windows XP, another alternative would be to install/reinstall service pack 3.
This version fixes errors, but may fail to install if errors wont let it.
In that case you will have to perform a system repair using your OS installation CD.
Download an official copy of service pack 3 from the link below:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en
Posted on Jan 04, 2010
  • 51937 Answers
SOURCE: Symphonic SC-3813 13-inch TV/VCR shuts down under 10 Secs
Could be a failing power supply
Posted on Oct 08, 2016
Tip
MacBook Pro Display housing coming off
If you don't want to spend a lot fixing your old macbook, this is an easy way to do it!
I hope it can help you.
keywords
MacBook Pro Display housing coming off fix
MacBook Pro display housing partly unattached fix
Macbook pro screen separating from the case fix
MacBook Pro unibody housing fix
Macbook Pro screen separation problem fix
MacBook Pro screen glass coming off fix
Broken MacBook Pro hinge fix
on Jan 29, 2016 | Apple Macbook Pro 13 - Brushed Titanium -...
The cords on each side of my convertable are broken how can i fix this problem can the top still go down
Tonya, Check the attached links, you can also search the internet for top repairers in your area.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Convertible Tops
VW New Beetle Convertible 2003 2010 Convertible top outer shell remove...
https://www.convertibletopguys.com/sitemap/view/107/volkswagen-convertible-top
Convertible Top Side Tension Cables
Mar 05, 2016 | 2005 Volkswagen New Beetle Convertible
Acer stuck on preparing to stand by
I would force power off, (press and hold down the power button) then start up windows and download any updates that are missing and then use the Shut Down command instead of the Stand By/Sleep mode.
Sep 11, 2014 | Computers & Internet
Lightning mcqueen tv will come on for a few seconds, then shut off?
Likely a bad connection in the set, considering a 13 inch it may cost more to fix than to just buy another set. Most of these 13 inch sets are not very well made to begin with.
Dec 23, 2012 | Disney Lightning McQueen TV
Ink cartridges will not move in place error # 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 - Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont...
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn't move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Jan 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
I get a 1200 error when trying to fax
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back ofprinter (2 screws), and bottom of printer (1). View the images below tofind where to remove the screws.
5. Cont…
NOTICE: The ink cartridges are all the way to one end. If the X4270 isplugged in, the cartridge carrier is stuck and doesn’t move. Afterfurther investigation a noticeable small black plastic lever ispreventing the ink cartridges from moving. Photo below shows lever upand down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200.Image on left displays lever up. Image on right displays lever down.
9. Lift the front cover open (if not already open) and plug in theX4270. Cartridges should move to center as if preparing for replacement.
Note: The cause of this problem is the spring slides out of place overtime, probably because of ink shed on one end of its loop and loopattachment.
12. Place spring in loop attachment and use hot tip of heated toolto melt top of loop attachment to prevent further errors. Melt top ofloop attachment similar of that to a mushroom top.
Feb 16, 2010 | Lexmark X4270 All-In-One InkJet Printer
Heater shuts down with C4-13 code
your not getting enough fresh air to it. where is it located? you need 1 square inch per 1000 btu's. it's having irregular combusion.
Aug 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Presario 2500 notebook boots up only to hibernate
Sounds like a poor power connection on the motherboard. Unfortunately, this isn't an easy fix - you have to completely disassemble the laptop and resolder the power connector. To check and see if this is the case, you can plug in your laptop, set it down on a table(so it doesn't move or get bumped), wait for it to start booting up, then gently wiggle the power cord where it connects to the laptop. If the computer shuts off, then it is, in fact, a loose connector.
Feb 13, 2009 | Compaq Presario Notebook
Computers & Internet Logo
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Inky Fingers
Inky Fingers
Fred Sops
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
