Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Fills up- does not drain
My washing machine will fill up with water, and once it does it does not agitiate or anything- I move the knob, then pull it up and it makes a humming noise.
Please help
Re: fills up- does not drain
Had the same problem with washer not draining at first last night, then today it wouldn't spin either. I was browsing around in here, and someone said something about a bad lid switch. My husband checked it out, and there was a loose wire in there. (Hard to get at, but if you can do it, worth it). Fixed the problem and good as new. Hope this helps!
Posted on Apr 16, 2008
  • 589 Answers
The couplings are relatively cheap, and can be found on Ebay for under $5. Just do a search for "whirlpool coupling".
It is pretty easy to change them, only a few bolts to take the motor off. The hard part is getting the outside covers off first!
If you're adventurous, you can do it without removing the covers and tilting the machine - but do this with extreme caution.
Posted on Jan 08, 2008
How to change the motor coupler to solve this problem. My washing machine does not spin.
Posted on Jan 05, 2008
  • 196 Answers
Sounds like a bad motor coupler. If the machine acts like its wanting to run, ie.. buzzing or humming then there is a breakdown between the motor and transmission. Replace the motor coupler to solve the problem
Posted on Jan 02, 2008
0 characters
3 Points
Kenmoore 800 washer doesn't do anything
Possible that the timer controller is faulty as it fails to switch or move in the cycle of the program
Use WD 40 to clean the switch, the knob can be replaced if this turns loose.
Jan 25, 2013 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
My GE WCSR2090D top load washer has flooded our house in the past, and when looked at by a repair man he said nothing seemed wrong... so we continued to use it and it now leaks/floods only once in every...
You might have a partially clogged drain past your drain hose
(In the wall etc)
Thats overflowing behind the washer.
Watch the drain for a few washings and see if it overflows
It may be second or third or fifth load. Its hard to catch
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
Sep 08, 2010 | General Electric WCSR2090D Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
The load starts like normal fills up but the knob doesnt move and it just keeps filling up. I can manually move the knob to drain the water but but it doesnt agitate even if i manually move the knob to...
Your knob is faulty and will have to be replaced. You can get one from or along with directions, pictures, and more.
Jan 20, 2010 | Maytag Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't act right
Most likely this is a problem with the main cycle knob, if for some reason the knob is not fully pulled
out, it just won't work, only fills with water, and the timer is the responsible one for the draining, but
the timer itself is not at fault, have your main knob selector switch checked.
Nov 02, 2008 | Maytag Performa PAV2200
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
98 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
