Husqvarna 160 CC Honda OHC Engine 21 in Logo
Posted on Aug 06, 2009
Engine running rich?
Engine running rich. Installed new plugs, cleaned out carb., reset float, put in fresh gas, cleaned both coils and set legs from flywheel at 10 thousandts. What can it be
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Aug 07, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
4833
Points
27
Worn float needle or obstructed airflow (plugged foam filter)
John Deere Snowblower 1032 won't start. Obvious solution?
First dump the old gas and put in fresh. Clean or replace spark plug.
Put a squirt of starting fluid in the carb. If it fires the ignition system is good. Do this a few times because there is still old gas in the float bowl and fuel line. When the fresh gas gets to the carb it will stay running. If it did not fire with starting fluid the points and condensor will need to be replaced and maybe the coil.
2answers
Working on a Briggs and Stratton 10T502-1457-B1. Runs rough and has black smoke coming from exhaust. This engine has no float to stick so that is not the problem. It does have a fuel primer bulb that works...
if you replaced the diaphragm and gasket below the carb and are completely positive they are installed correctly and not damaged, then the carb is defective and they usually warp or the primer system goes bad
1987 Dodge Dakota 3.9 engine, Holley 2 barrel. Having running issues. Bought the truck cheap cause it wouldn't run. Cleaned the carburetor and installed a rebuild kit. Starts right up and idles great....
Yes, the floats may be causing the fuel level in the carb. to be too high. The black plugs indicate running too rich. Clean the plugs and check the fuel level.
I have a toro super cycler gts 5 model 20475 6.0 engine i put new gas in it a new spark plug but if i loosen the gas bowl no gas come out and it wont start what could be wrong
Ensure fresh gas is in tank. Follow gas line from tank to carb. Have locking pliers ready to pinch off gas line or close gas line valve. Remove gas line from carb. observe gas flow to carb. Remove carb bowl from bottom of carb. Attach gas line to carb. Does gas flow to carb. Observe float, float down gas flows, float up no gas flow. If float is bad replace float assembly or carb. Remove float mounting pin and needle metering valve. Use a bread wrapper pealed back an inch so thin wire can clean out port of meter needle. Use wire to clean out center port. Observe bowl screw look for hole thru screw, clean out with wire if preset. Re-assemble carb. Clean replace air filter. Fill oil. 30w. Prime motor, pull rope 10 times to start. No start, replace carb.
I have a 85 gsxr 750 running rich on the left
Hi Chris,
You will have to recheck the float level (in the float chamber) of those two carburators, reset if necessary.
You may also have to reset the air-mixture screw for both of those carbs. Standard procedure to set htem is tighten them all the way in making sure not to over tighten to avoid damaging the sharp end of the screw, and thn to open 2 and a half to 3 turns.
You can thn reset them as the engine is running + -- either way.
Hope this helps!
1helpful
3answers
My honda 400 bros is not runing right 1 plug is wet the rest is sutted up as if runing rich what would think it is
Sooted plugs proves tht the air-mixture is too rich.(too much fuel going to the combustion chamber)
You have to set the air-mixture screw on the carb/s.
Clean the carb/s, replace 'inline' filter , if you don't have one ..install one, reset float level.
It's better to also check the valve clearance too.
Fit in new plugs (gapping them to specs.) and run the engine to its normal temperature thn set the air-mixture screw...standard setting....all the way in i.e. tighten it slowly to the end making sure not to damage the tip of the screw, thn 2 and half turns outwards to 3.
Start the engine....run to normal temperature and thn reset the air-mixture screw +/- either way.
Hope this helps!
4helpful
2answers
Craftsman eager-1 3.75 mower will not stay running
the engine is not getting enough gas. when you hold down the primer you are bypassing this problem. to fix this simply adjust the carb's fuel screw, located on the side of carb, a little at a time until runs smoothly.
My 2004 springer is running rough put new plugs in it let run 5 minutes plugs fouled out black smoke out pipes any suggetions?
Hi ,
Your bikes engine is running too rich !! , you will have to set the air-fuel mixture ratio.
Try to check the air filter it may be too dusty and kinda clogged thus not allowing air to go in.
If all is ok thn you may have to clean the carbs and reset the float in the carbs.
Knight.(YamahaSeca XJ 750 A 1981)
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
