You can use a different bolt other than a replacement bolt from the mfg. as long as it's the right diameter, thread pitch, and length. eg: 10x1.25x40 = 10mm dia. x 1.25 thread pitch x 40mm long. The problem usually is that the head on the bolt for that diameter is too small and you'll have to use a washer. That's ok but if the head of the bolt is too tall, the bolt will hit the ground first, keeping the head unit from releasing some trimmer line.
SOURCE: how do i replace a shaft for ryobi whipper snipper
I never heard it called a whipper snipper before but I am on this side of the ocean. you should be able to go to www.ryobiuk.com. Put in your model number and you should find a parts list for it.
HTH
Good Day. mate
SOURCE: pretensioning starter cord on ryobi whipper snipper.
This was answered in a previous solution
