Question about Whirlpool Dryers
Whirlpool duet steam dryer model WGD95HEDC0. Lint filter will not go all the way down. Most lint is out. It looks like the right side flap is warped. Can this be the problem & how can I replace it?
SOURCE:
  • 77 Answers
SOURCE: lint fell back into lint trap. how can i get it out? already looked in back.
An appliance store can sell you a brush that is attached to a long wire. It is made specifically for removing lint from dryers. I have seen them at walmart and other places but for sure at an appliance store. Good luck.
Posted on Apr 20, 2009
dawson57
  • 25 Answers
SOURCE: Lint fell down the lint trap. How do I get it
Luckily, dryers are light. Best thing to do is pull it out until you can remove the back cover. (unplug it first) Then vacuum and clean all the dust and lint you can. This should be a yearly thing at least anyway. Replace the back plug it in and slid it back. I do mine every 6 months or so.
Posted on Jul 13, 2009
  • 66 Answers
SOURCE: Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
Posted on Dec 12, 2009
SOURCE: Whirlpool Duet Dryer - Working but no heat
i need help fixing my 5 year old dryer. whirlpool duet model GEW9200LW1. I have replaced the thermistor. I tested (with an ohm meter) the heating coil, thermal fuse, high limit thermostat, & heating element and they were all fine. I replaced the electronic control assembly and the user interface. THE DRYER STILL WONT HEAT.
Then it occurred to me that the sensor may not allow the dryer to heat if its not sensing wet. Could this be true? Have I been trouble shooting this wrong?
Help me.
Posted on Jun 25, 2010
SOURCE: Finding Lint Filter on Kenmore 70 Series Model 110
I've got a Kenmore 70 Series, Model # 82370120 washer and the lint filter in under the machine. I had to tip the thing over to get at it.
Posted on Nov 02, 2011
Broker parts in dryer slot
Are you talking about the little door that closes when you pull out the lint screen, then opens when you put the screen back in? Did you get all the parts out of it when it broke? If so they put that in there to keep stuff from going down into the fan housing in case the filter was left out by accident. If the filter will still go in and out ok, and you got anything that broke to keep it from going into the fan, you will be fine, as long as you don't forget to not put the filter back in when your done.
Nov 11, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a whirlpool duet model gew9250pw1 dryer it gets good and hot put when the cycle is done some of the clothes are still damp.i not sure if it is the timer or a censer. i know when we start it the...
Look for an airflow blockage. Be sure lint filter is cleaned and if lint is accumulated in the air stream path, take a vacuum or brush and clean it out. Dirt and lint are a dryer's worst enemy.
Mar 17, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool gold ultimate II electric dryer and would like to know how to remove the front and side panels to remove the lint on the inside.
Hello, If the lint filter is under the flap at the top lift the flap up and remove the 2 screws. Slide a putty knife under the lip between the top and the front panel about 3 inches from each end and push in the clips holding the top down. Lift the top up and look inside the machine either side and remove the 2 screws you see. now lift the front panel off. you now have access to inside the dryer :) Hope this helps! Mike
Oct 30, 2009 | Whirlpool LGB6300 Gas Dryer
Trying to locate thermistor whirpool dryer and replace it
Just bought a new thermistor for the Whirlpool Duet dryer and ready to install, does it has any polarity; ie. does it matter which wire goes to which side?
Jun 16, 2009 | Whirlpool GEW9250 Electric Dryer
Apr 19, 2009 | Kenmore 22422 Top Load Washer
Gas Dryer - takes to long to dry
Friend,
huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.If the vent line is kinked or blocked
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
Take the vent line off the rear of the dryer and try if it works. If it does you know it's the vent line and not the dryer that's the problem the dryer.
You will be fine
Bless You huuum
Feb 01, 2009 | Whirlpool LGR3624JQ Gas Dryer
I have a whirlpool duet electric dryer. It is not spinning, but going down on time. what is wrong with it.
easy easy easy, you need to replace your belt..take out your lint filter, you will notice 2 screws, unscrew them, pop the top up using a putty knife or flat screw driver, you have clips on the left side and right side. you will notice your belt is broken
Apr 02, 2008 | Dryers
Whirlpool Duet Electric Dryer 4yrs old, not drying the load completely
The sensors are two metal strips inside the drum. They are on the right side just behind the filter. They are silver colored and have a slight curve to them. You cannot see them unless you put your head inside the drum. I clean my sensors with a non metal pot cleaner like 3M Scotch Brite. These sensors also fail if you dry silicon backed carpets.
Jan 20, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Lint trap
There should be a rectangular flap on the top panel at the rear right of your dryer. the lint filter is in a chute if there is just a hole here then the filter is missing.
Mar 15, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryers Logo
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
