Question about Whirlpool Dryers
I am getting a F1 fault code on my Whirpool cabrio dryer
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 30 Answers
Depending on the year, the F1 code is a control board fault. If the dryer does not start (clicking noise heard but drum does not start) it may be a solder joint on the board has cooked. If you are handy it is a 15-20 minute fix.
Posted on May 02, 2019
SOURCE:
SOURCE: Whirlpool Cabrio Washer Error message code F1
I have started a petition to be sent to the CEO of Whirlpool Corp., Jeff Fettit.
Follow the link, and please sign it! The more the better! Spread the word!
You may also copy and post it to any other groups/discussions about this problem.
http://www.petitiononline.com/cabrio08/petition.html
Thank you!!!
Posted on Aug 02, 2008
SolutionGuy
  • 331 Answers
SOURCE: AF flashing on our Whirpool Cabrio Dryer.
Hi Terry,
AF flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
I suspect it's the vent connecting the dryer to the wall or the vent pipe in the wall to the outside. Without moving your dryer, look behind it to see if the flex duct is crushed or pinched. If it is, it's pinching off your air flow, too. Pull the dryer out straighten or replace the hose (you can get vent hose at Home Depot, Lowes or Ace Hardware) then slide the dryer back being careful to keep it about 8" from the wall (8" is the recommended distance from the back of the dryer to the wall, btw).
If the flex vent is NOT pinched off, then you should call a chimney sweep to come out and clean the vent pipe that's in the wall.
*Note---> If you want to test this diagnosis to verify it, just disconnect the flex hose from the wall and run a load of clothes. The error code should not reappear.
SG
Posted on Mar 27, 2009
  • 3 Answers
SOURCE: My Whirlpool Washer Cabrio model# WTW6200SW has a
Called 1-800-253-1301 was told by the Whirlpool agent that there was a quality issue associated with the F1 fault code. They would take care of parts and labor free of charge! My machine is 28 months old. Talked to a woman named Valerie.
Posted on Apr 19, 2009
canbruce75
  • 1776 Answers
SOURCE: f1 code on whirlpool cabrio top load
This is from a service bulletin. This may be of interest to you. There have been many problems with these machines in this area. Anyway, I sympathize and hope this helps. Best wishes.
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 – CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
with the air pressure system.
Posted on Aug 09, 2009
canbruce75
  • 1776 Answers
SOURCE: My Cabrio dryer is flashing f1. What does this
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
the tub.
Comments: - I don't know what satifaction they will give you, but you could contact Whirlpool. I don't know if it's fact, but some folks with this problem said that they were able to get the cost of repair covered in some cases, while others complained that they got no proper assistance from the manufacturer at all, so I really don't know for sure what good it will do, but it's worth a try. I'm sorry for your trouble and hope you find a good resolution to your problem. Best of luck and best wishes.
Posted on Sep 10, 2009
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    What does F1 mean on a whirlpool cabrio dryer
    You can google whirlpool cabrio dryer codes and find the code that you are looking for. I just looked it means your dryer is not heating.
    http://dryernotheating.net/whirlpool-cabrio-dryer-f1-error-code/
    Aug 02, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
    F1 code on my Cabrio dryer
    According to the manufacturer the "F1" error code means a primary control failure. The correction is to replace themachine control assembly. Here is the part to order.
    The part comes with a 365 day, any part, any reason return policy.
    Nov 12, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
    Keep getting F1 error code on my cabrio whirpool top load washer. Can you help?
    Hello & Welcome to FixYa
    F1 error in your whirlpool cabrio indicates bad control board and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known to be a common issue. Please get back to me if you have any other questions.
    Kevin
    Sep 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    OUR WHIRLPOOL/CABRIO MODEL WTW6600SW2 IS FLASHING F1. WHAT IS PROBLEM?
    Lool on this site for F1 fault. Apparently a very known problem, seems with control pcb. I called Whirpool today on a machine purchased in 4/07 with a 4 year extended warrenty from Lowes, and they didn't even question it. Said a repairman would be out to replace part and parts and labor are covered by Whirpool. Call them at their 1800 #, Mention it's the infamous F1 fault, have model and seriel # at rear of top load door ready for the technical help person, and they'll take care of it.
    Dec 08, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    My washer was supposed to go in to spin cycle and alarmed with I believe F1. Is there anything I can do to fix this problem
    There is a recall for the Cabrio for having the "F1" error(I had mine fixed by whirpool for free). Sounds like you are getting the F1 error code. If you have not had the washer repaired under the warranty program then you should give Whirlpool a call and get it repaired under warranty. When you call them say that you are getting the "F1" error code and have read on the internet that there is a recall. Have your model number,serial number and date of purchase available. They will send someone out to inspect the washer and repair if they have the control board in stock(they had to order mine and it took 2 days for it to arrive). I also located the phone number you will need to call for service...1-800-253-1301
    Jan 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Only runs 2 mins then shows F and i clear it try to restart it it will start to fill then shows sd
    Dec 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Dryers Logo
    Top Whirlpool Dryers Experts
    Craig Butler
    Craig Butler
    Marvin
    Marvin
    Smitty
    Level 1 Expert
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
