SOURCE: Err on CD player....2005 Honda CRV
it sounds like it may have a bad laser or even dirty try removing the cover and gently cleaning the lens if you dont feel confident i would suggest you put it in for a repair usually removing the battery lead for up to half an hour will reset the system and put it back to its original state but its suggested if it doesnt then its internal usually the laser.
SOURCE: ERR
Solution is very simple - just press DISP/MENU and STOP simultaneously for 2-3 seconds. There will start the FOR blinking on the screen of recorder (ERR will disappear) and the red "eye" on the switchboard. Wait for few minutes and your recorder is back to work :)
Warnning: This means FULL restart and you will lose ALL your recorded data! But I did not find any other solutions...
SOURCE: HealthSmart bathroom scale displays "Err"
Put scale in round file can. Buy another cheap scale.
Testimonial: "The new scale works great and was on sale at Wal-mart for only $29."
SOURCE: cd player wont work in sebring car
try with a good know disc this means not a copy if problem persist need to send unit to be repaired
SOURCE: screen shows ERR. I changed batteries and tried
You're right..This happens often when one changes the battery.Here's what to do :
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in ALL the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again.
Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
