Can use 6917L-0085a for replacing 6917L-0085b LCD driver board?
    Habit-Forming:
    New Friend:
  • 59 Answers
It should work. The a and b mean one was made before the other. (example a 2012 b 2014).
Posted on Apr 23, 2019
SOURCE:
LG 55LH90-UB LED TV I have an LG 55LH90-UB LED tv that has, what seems to be, sections of dim areas.
Hi ,
try swapping the screen with another one to just see if it is behaving the same, because some times the screen circuitry or the led screen could be damaged .
good luck buddy
May 18, 2017 | LG Televison & Video
My Samsung TV has audio, no backlights, but I do see and image with a flashlight. Do I need a new power/lcd driver board, or new LCD lights?
. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 26, 2017 | Samsung Televison & Video
I have a models-0085a sub with s-video connector need to know where the wires go to need a schematic
one end goes to the tv and the other video card both have round holes to go in
Mar 09, 2014 | Computers & Internet
Lcd tv 32inch negative picture
negative picture is a fault with the screen driver it may not be connecting properly and a cleaning of the board may be all it needs. failing this it may need a new or replacement screen driver. the driver is located on the back of the screen. on top of the board there are clip connectors. take board off and with a ruff cloth clean the copper end to the screen, brush off the dust of the rest of the tv and boards and in the gaps in the screen controller board. then put back together and see if it has sorted it. if not it will need replacing.
Sep 06, 2013 | Samsung LN-S4692D 46 in. LCD HDTV
II have a blue line from top to bottom about 5"
hi,
There can be two possibility for this problem. Lcd driver (T-CON board) or the lcd itself faulty. In most cases the lcd driver will become faulty. I have added a picture bellow. There is a circuit board inside your tv like this Covered by a metal cover. Remove the metal cover. You will see there will connection on three sockets. of which 2 will go to the lcd panel and one will go to the mother board. Before replacing that board carefully remove the wires from the sockets and then reconnect the same. some time improper contact can cause this problem.After that check the tv. If then also the problem remains you have to replace the T-CON circuit board . Have added the picture of T-CON board for your refference.
ok
Sep 10, 2011 | Vizio L32 32 in. LCD HDTV
Half of the screen goes black, white, gray and blue lines while the other half still showing tv program
hi,
There can be two possibility for this problem. Lcd driver or the lcd itself faulty. In most cases the lcd driver will become faulty. I have added a picture bellow. There is a circuit board inside your tv like this Covered by a metal cover. Remove the metal cover. You will see there will connection on three sockets. of which 2 will go to the lcd panel and one will go to the mother board. Before replacing that board carefully remove the wires from the sockets and then reconnect the same. some time improper contact can cause this problem.After that check the tv. If then also the problem remains you have to replace that circuit board as whole.
ok
Jul 18, 2011 | LG 32LH5000 32 in. HD-Ready LCD TV
TI-84 plus calculator - broken LCD screen -- user replaceable?
The lcd is connected to a PCB with a driver, you can unsolder the LCD pins from the driver board. I think you are able to unsolder the entire board+LCD from the main calculator board, but I haven't tried that.
Your best bet at finding a new LCD would be to buy broken calculators off of ebay.
Sep 09, 2010 | Texas Instruments TI-84 Plus Calculator
How to replace backlight in a westinghouse 37" lcd tv? and where to get replacement backlight? model LVM37w3....
Backlight board,It call a LCD inverter board,it long board in shape.After take the tv backcover out.Replaced this board pretty easy just require a philip screw driver take out about 6 pilips screws,and few cables connections.Do the reverse to connect.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.
Mar 30, 2010 | Westinghouse LVM-37w3 Television
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
