Question about Sony Televison & Video
Locate the the optic block on my sony kdf-e50a10 tv
SOURCE:
tvtechnician
  • 105 Answers
SOURCE: optical block
the optical assy is a large amount of work i wouldnt recomend doing it yorslf at all. please leave that to the pros. you have to completely disassemble the tv from the back. i can do it myself in about 45 min.
Posted on Oct 13, 2007
ctf1800
  • 4402 Answers
SOURCE: Sony Grand Wega KDF-E050A10
Authorized sony repair center told me the problem was the Q Box. Ever heard of this? Part runs about 300 bucks. TV is out of warrenty as it is 2 years old. Do you think it is worth it to fight sony and get them to replace the part or just fix the TV?
Part Number is A1167541A, service rep called it a Q Box in the diag, however the web says its the b block assmy.
read this if you think it's the same problem
Posted on Feb 01, 2008
  • 197 Answers
SOURCE: Blue dots on Sony rear projection LCD tv KDF 42WE655
you have a bad optical block
Posted on Jul 02, 2009
  • 117 Answers
SOURCE: Sony KDF E50A10 tv starts up but then shuts down
most likely power supply fault buddy/get part no search google
Posted on Jan 05, 2010
How to fix in center of the screen a white sprider image affect?
you will need a new one of these sony optical block 1-788-303-21 kdf-e50a10. when it over heats the picture will go strange also just sometimes there is a build up of dust blocking the light in the chamber in the optical block you may be able to clean this out but any scratches you make on the glass will be seen when the tv is on. also there is a lot of resting to do when you put back you have to re-aline the output to the screen size using the adjuster.
Sep 21, 2013 | Sony KDF-E50A10 50 in. LCD HDTV
I own a Sony KDF E50A10 3LCD TV that has developed a purpleish defect in the lower, center portion of the screen. Do you have any ideas on how to fix this?
It is an Optical Block Problem, Sony has settled several Class Action Lawsuits covering many models from 2002-2010. Start with this Link, it will provide you a very good starting point. Hope this helps
http://sites.google.com/site/sonylcdrptvproblems/
Jun 01, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
I have a Sony TV model # kdf-E50a10, there is a shadow in the middle of the screen . I can still see the picture, but there seems to be a cloud in the center of the screen. How can I fix
problem is called the optical block assembly. repair runs around 1200 dollars. if you call sony with your model# and serial # they may offer you a new tv at a discounted price. 1800-282-2848
Mar 24, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
How do I find out which lamp is blown? My screen has a lot of yellow throughout it. It is a Sony KDF-E50A10.
It is dlp tv that has one lamp as back light source. Yellowish tint is problem of Optical Block Unit (commonly known as light engine) that will be replaced to fix it.
Local tech will help you in optical block unit replacement because it is purely job of qualified tech.
Thanks.
Apr 06, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
I have a blue line in the top left corner of my kdf-e50a10
The Optical Block needs to be replaced. I would call Sony and see if it qualifies for a recall repair. If so, Sony will pick up the cost of install.
Their Customer Support # is 1800-222-SONY
Skyassoc
Nov 25, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Hello! I have a problem with my kdf-e50a10 sony wega. When i watch TV i see a yellowish vertical line right in the middle of my tv is like 10 inches wide, all the way from the top to the bottom of the...
This is caused by a failure of the optical block of your TV. The only way to fix the issue is to replace the whole optical block which is very expensive ($1000+) and time consuming (need to take whole TV apart to replace the part).
The optical block in your model had inherent issues and there is currently a class action lawsuit pending against Sony for this issue. Up to date information reguarding the lawsuit can be found here: http://www.sonya20tvclassaction.com/main/home.sfx
Oct 07, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
The picture has a yellow shadow and green tint
needs an optical block, contact sony and ask about the "optical block'' program. you should be able to get it for free. Julio
Aug 03, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Replaced bulb and still have red line at top of TV any advice
see sony website - extended warranty for this problem. It needs repair service to replace the optical block. I just had the same problem - they come to your house to repair free of charge.
Mar 02, 2009 | Sony (XL-2400) Projector Lamp for...
Optical block
I think, Lamp compartment locates at rear side near cooling fan. Open the cover and pull out the lamp. Please Don't pull HOT lamp.
May 27, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10
You may want to have the optical block checked out. Usually when you see spots or blotches of color it's due to a malfunction of the Opt. Block assembly.
Feb 22, 2008 | Sony (XL-2400) Projector Lamp for...
Televison & Video Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
