Question about DISH Network Televison & Video
40" led did the channel auto scan for cable getting,scan runs but then goes to blue screen and says run auto scan again? I have Dish Network
    Sergeant:
  • 204 Answers
Did you connect to the output of a box? If so then it will usually come through your him I and doesn't require a scan. If cable set your menu setting to cable and not antenna.
Posted on Apr 23, 2019
SOURCE:
  • 579 Answers
SOURCE: cannot watch channels past 13
Your tuner settings must be set on broadcast instead of cable. Below channel 13, they use the same frequencies so it doesn't matter. Find the tuner settings page in the menus and change the cable/air setting.
Posted on Jan 06, 2008
SOURCE: how to run channel auto scan
Okay here's how you do it. Sadly they buried this DEEP in the user guide and I stumbled across it -
Press the TV Menu button then with the < or > arrows scroll to the Channel menu. From there you can select the auto scan.
Posted on Jan 10, 2009
maatmartin7
  • 1255 Answers
SOURCE: 27F520T RCA Truflat, won't scan for channels, auto or manual, only blue screen, no channels on tv
You need to replace the microprocessor. GoodLuck there is 52 pins to unsolder and resolder a new one. The price for the chip may bee about $35
Posted on Jun 26, 2009
  • 16 Answers
SOURCE: it ask to please run channel auto scan
just press the key that displays on the screen when it ask run channel auto scan or go to menu and channels find auto scan then press enter
Posted on Aug 26, 2012
lss10
SOURCE: Channel/clock auto set
Press both eject buton and rewind button
Posted on Sep 05, 2012
Auto scan not working??
Make, model, and year please.
Jan 22, 2016 | Televison & Video
Dish network Blue screen No "Signal
Hi john harrison!
A blue screen with "No Signal" is usually related to a video problem. The TV may be getting changed off the correct input/channel, or the video cable might be going bad.
If you have a spare, I would recommend a different cable and seeing if that fixes the problem. If it continues, verify the input/channel your TV is on when it receives a picture and if it goes out try putting it back on that input/channel.
If problems still continue I would be happy to review additional options with you. You can reach me here or at thomas.faust@dish.com
Tommy Faust
DISH Social Media Representative
Jun 03, 2012 | DISH Network Televison & Video
I have Vizio I changed cable from Dish Network to a Local Co. now I can't get cable or sound, although the cable box is all lit up. I get a blue screen with no signal running across it and I have
check with whoever is your current signal provider---paying for service they will usually come out and make sure it is working either via the coax fitting or via the audio/video jacks
May 17, 2012 | Vizio Televison & Video
Hi, I have the Dynex 32" flat screen TV. I have a Dish Network cable that I unscrewed from a smaller tv next to it, into this one and the PLEASE RUN CHANNEL AUTO SCAN message comes up, even after...
There are a few things that can cause this. This may be an issue with the TV itself or with how your DISH Network is set up. Are you able to change channels at all; with the remote or the panel buttons? There are many things that we would need to go over. But you will want to make sure that your DISH is connected tightly to the TV. Please email me so that we can get this resolved!!!!
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Aug 27, 2011 | Dynex 19 in. LCD Flat-Panel HDTV
How do you scan the channels on the PDH42L40? I need to go to a certain channel on the TV to get my Dish Network to work. It is not hooked directly into a box, it is on a secondary receiver. Please...
hello and good day to you!!!!
if you wish to scan your TV to go for a certain channels..
you need to reset auto scan on your TV...
this are the procedure on how to reset auto scan...
  1. Get your remote control..
  2. press the menu button on your remote
  3. go to the settings..
  4. try to find the auto search.
  5. after you find the auto search press enter to scan the channels.
Note: Please complete the 100% scan for better results..
Jul 12, 2011 | Televison & Video
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
Hi, my Phillips was hooked up and working fine directly to the DISH receiver using the HDMI 1. I moved and had to put the DISH receiver in another room and ran a coax cable to where the TV is now using...
Hey murphypat321,
Sounds like the TV may need to be on ch 73 cable rather than 60 air. Try switching the TV to 73, if it goes to 69 then put back on 60, if goes to 73 good. Once you have that set go to your TV1 and bring up the menu. Go to System Setup (6) -> Installation (1) -> Modulator Setup (5) and change the TV2 setup to either cable if on 73 or air if on 60 and the picture should come in if everything's hooked up.
Hope that helped! You can email me at thomas.faust@dishnetwork.com if the problem persists.
Tommy Faust
DISH Network
Mar 09, 2011 | Philips 42PFL5332D 42 in. LCD Television
Hi! I have just tuned in a new TV. However, the channel menu does not offer the numbers 3 to 8 including ITV&lt; Chanels 4 & 5. What do I do now?
julietterobi
If this is a new TV, you could run an auto scan so the TV can find the channel it needs to get the satellite signal. What type cable is connected between the TV and receiver. For a coax cable, the TV would be on channel 3/4 (usually 3). For an RCA (yellow, white, red) cable, component (green, blue, red, white, red) cable, or HDMI, the TV would be on an Input setting. I hope this helps.
Ray Calo
DISH Network
Jan 10, 2011 | Televison & Video
Samsung tv power cycles when I get to higher channels pass 40. I attempt to change channel. Doesn't change and then front led blinks, tv screens goes blank, led flashes again and then screen is normal. I'm...
We have a similar problem when changing channels/surfing, the TV will begin to power cycle, until you unplug THE CABLE TV input, then it will turn on again and stay on as you rehook the cable and change channels....till it decides to do it again, DTV channels seem to trip it up, but not sure....if I leave it on the same channel it will run for days. Yep and the cable TV is grounded outside
Dec 19, 2009 | Samsung LN40A630 40 in. LCD TV
No signal on TV2 with dishvip622.
If the blue light on the receiver is on then your tv is most likely on the wrong channel after checking cabeling i would do a reset on receiver first wait for it to come back on, then run a channel scan on your tv2 you can do this with orignal tv remote under the menu options. its also refered to as a auto search or auto program.
Nov 30, 2008 | DISH Network ViP622 DVR DTV Receiver /...
Televison & Video Logo
20 people viewed this question
Top DISH Network Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
