Question about Sylvania Televison & Video
Sylvania S9000-Portable DVD Player don't play when theres a disc in the machine,it just say no disc.why??
SOURCE:
ginko
  • 19396 Answers
SOURCE: PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Posted on Feb 10, 2009
petraman7
  • 1175 Answers
SOURCE: my portable dvd player shows no disc when i put my dvd in player
Hi....
Very lightly clean the laser lens ( looks like a very small eyepiece)
with 91% or better alcohol on a swab. Then very lightly dry it off.
Also..have you tried another DVD or CD in it?
Check for dust or debris in where the laser pickup is
Posted on Feb 25, 2009
SOURCE: my toshiba portable dvd player (sd-p1900) won't
i had this same problem, its likely a disconnected ribbon wire off the drive, One I plugged that in it read/spun the disk, now I just need to get the screen to stop being blank white heh. Good luck ^^
Posted on Jul 20, 2009
  • 111 Answers
SOURCE: Dvd wont play
Maybe the laser is broken. You should send it back for repair.
is it an original dvd?
Posted on Apr 22, 2010
fieldy14
  • 456 Answers
SOURCE: my Toshiba portable dvd player says no Valid Disc
If the units under warranty you may want to contact Toshiba as it sounds your unit is in need of a replacement laser assembly.
If the unit isnt under warranty, Toshiba should be able to supply the parts you need and as long as you mark every thing that you remove, as to know where it goes when re-assembling the unit. The lasers arent difficult to replace. Good luck.
Posted on Jun 07, 2010
My 9" Coby V.ZON TFDVD9109 Swivel Widescreen Portable DVD Player won't charge but will turn on and stay on as long as I have a charger hooked up what can I do about that
Coby TFDVD9109 9-Inch Widescreen TFT Portable DVD ...
www.amazon.com/Coby-TFDVD9109-9...Widescreen...
Amazon.com, Inc.
Rating: 3.6 - ‎52 reviews
Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ... has never been easier with the Coby TFDVD9109 9" Portable DVD Player. .... The DVD player finally stopped working, won't load discs anymore, gives error message. I had a ... I'm currently doing my research for a new a player but likely will end up ...
Coby TFDVD7009 7-Inch Portable DVD/CD/MP3 Player, Black
www.amazon.com/Coby-TFDVD7009...Portable-Play...
Amazon.com, Inc.
Rating: 3.7 - ‎240 reviews
Ac Power Adapter Cord for Coby Dvd Players Tfdvd1029 Tfdvd7009 .... So in my case 5 zone is needed and it worked well. ... There is inconvenience in charging. ... that once you unplug the battery the connection is so cheap that it won't reconnect. .... Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ...Missing: tfdvd9109
Coby Electronics TF-DVD7006 7-Inch Widescreen TFT ...
www.amazon.com/Coby...DVD7006-Widescreen-Port...
Amazon
Jan 10, 2016 | Coby Televison & Video
No Disc when loaded
The player is not a able to read that DVD format, or the DVD is a defect:
Jan 11, 2013 | Sylvania SDVD7002B 7 Portable Dvd Player...
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
My sylvania portable DVD player won't read discs the display says No Disc after the spin. What do I do?
I had same problem with a sylvania portable DVD: no disc. After cleaning the laser didn't work, I took the unit apart, and found that there is a small gear that moves the laser back and forth across the disc.. The gear could easily be misaligned with a rough bump along the drive.. All I did was realign the gear to the center where the disc was. Inside, there was even a small lever to pull back on to do this.. I also noticed a small Ribbon cable connecting the laser to the main board. Again, seemed nimble. I detached the ribbon, cleaned the connectors with alcohol and reattached. Happy to say, it works perfectly now. :). Good luck.
Oct 10, 2011 | Sylvania SDVD7027BL Portable DVD Player
Portable DVD won't play DVD but will play disk cleaner....
Change the motor disc spindle they loose velocity that´s why don´t play dvd´s
Nov 04, 2009 | Philips PET702 Portable DVD Player
SRD4900 Sylvania DVD/VCR Combo
Well first of all, why the hell would you press play when there was nothing in it???
Feb 01, 2008 | Durabrand DUR7 Portable DVD Player
Televison & Video Logo
19 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
