Question about Tascam Audio Players & Recorders
My tascam cd-rw 700 turns on and reads welcome and over but wont open
SOURCE:
mjap
  • 107 Answers
SOURCE: cd player reads disc error
maybe you need to change the optical eye now.
but first try to adjust the variable resistor/trimpot resistor.
try this options to your player.
(TIP)
if using a cd/vcd/dvd products, we only should play a cd/vcd/dvd dics without a bad scratches. the scratches are making the optical eye worn-out easily.
Posted on Jan 30, 2008
SOURCE: Tascam Mixwell - CD-DJ1
on putting in the cd and shutting the lid an error occurs. on the screen it reads' remain err sled' and the cd is not spinning. what is the problem???
Posted on Feb 16, 2008
  • 1019 Answers
SOURCE: disc read problem (Tascam CD-RW 750)
Run a laser head-cleaning disk through it.
Theres probably a spec of dust on the Laser.
Mike @ Compurepair.
Posted on Feb 22, 2008
  • 3 Answers
SOURCE: Problem with Tascam Cd-RW750. system error at
hello ,, how can i find optical pickup for TASCAM CD-RW 750 RECORDER ,,, what is the number of this optical please somebody help me ,, thanks ,ferr
Posted on Sep 27, 2009
SOURCE: CD-RW 700,IT TURNS ON OK,BUT WHEN I PRESS "OPEN"
The power source on the unit might be shot. The reference voltage on the yellow wire to the main drive should have a voltage of 5volts dc current. Usually the unit will freeze up after the third click because the voltage is not sufficient. Have a qualified tech look at the power suppy for the unit
Hope that helps
Posted on Dec 16, 2010
Tascam cd -rw 900 sl wont play cd burnt from my laptop
Make sure you are burning the audio files in a format it can read. The standered is Mp3, but some times you need to burn them in other formats.
Apr 05, 2014 | Tascam CD-A500 CD Player
Tascam CD-RW700 Not Working
Mine is doing the same thing. By pluging and unplugging the power back and forth sometimes I get it to read the disc and it stays on. If you get yours going then I suggest always leaving it on. It doesn't draw much. A temporary solution until you figure out how to fix it.
Apr 22, 2013 | Tascam Cd-Rw700
When turning on cd recorder it don't go past welcome, it freezes there, it a Tascam 222 cd recorder,What's wrong with it
try holding f8key be for it says windows and then either reboot or go to last go running go figuretion
Nov 09, 2011 | Tascam CC-222mkIII CD Player / Recorder
My tascam cc-222 read welcom want open
Is there a CD stuck in the unit? Did you push the tray to close? If non of the above you must remove and open the top to see what happened
Jul 08, 2011 | Tascam CC-222mkIII CD Player / Recorder
The CD tray will not open after the "welcome"
I hope you already have found the answer, but, I have 20 some odd Tascams in the field and this is the training that I give my operators. When a defective CD is in the drive (or one that the unit thinks is defective) you can turn off the machine and let it power down. Then when you power it up keep pressing eject before it has a chance to read the disk. It will go into eject mode before it will go into diagnostic mode and when the disk is out the machine don't let it go back in. Most of the time the machine goes back to working like it should.
Jan 31, 2011 | Tascam CC-222mkIII CD Player / Recorder
CD-RW 700,IT TURNS ON OK,BUT WHEN I PRESS "OPEN" ALL THAT HAPPENS IS THE CLICKS LLIKE THREE TIMES.WHAT CAN BE DONE FOR THE HOME STUDIO GUY?
Hope that helps
Sep 25, 2010 | Tascam CD-RW2000 Burner
How can I find this optical laser ?? , please
hello somebody help found this optical laser for TASCAM CD-RW 750 . who can i find , what is the number ??? thanks
Jul 15, 2009 | Tascam CD-RW750 CD Recorder
Problem with Tascam Cd-RW750. system error at start up after the "welcome". Then it opens the cd tray and does nothing else.
Jun 07, 2009 | Tascam CD-RW750 CD Recorder
Tascam CD-RW2000
THE CARRIAGE UNIT (CD TRAY) is damaged, replace the tray
or the drive
or u can use it as is until its dead
Nov 08, 2007 | Tascam CD-RW2000 Burner
18 people viewed this question
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
