Question about HP PSC 1315 All-In-One InkJet Printer
Installation of PSC 1310
I am unable to install PSC 1310 . Message comes " print spooler service is not running"
Please assist with solution.
Mital R K
  • HP Master
  • 1,113 Answers
Delete driver unplug from pc, download and install driver, connect when prompted
Posted on Nov 30, 2007
Spooling error
Right click My Computer > Manage > Services and Applications > Services > Print Spooler. Try stopping and starting. Make sure it is set to Automatic and Login is Local System.
If this is in office network, then IT needs to handle. GL
May 31, 2013 | HP psc 1310 series
The print spooler service is not running.
Reinstall the printer drivers will shore it up quickly the spooler has to do with the printer so do that and you should be fine.
Apr 23, 2009 | HP OfficeJet 4215 All-In-One InkJet...
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using
Jan 27, 2009 | Office Equipment & Supplies
Trying to install the HP Deskjet F2210 printer onto my Dell with windows XP everything loads except the printer spool. What do I do?
Restart the Print Spooler:
start-> run-> type services.msc-> scroll down to the print spooler service n hit start.
Verify that that the Print Spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print Spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print Spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try uninstalling all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print Spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print Spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP print spooler problem and error 1068. Want my printer back!!!
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
Nov 23, 2008 | HP PSC 1610v All-in-One Printer
HP PSC 1400 series printer won't load
Hi Flame,
Please click on the web link given below and perform the steps as provided in the web page to fix the installation issue.
Make sure that you have completed all the steps perfectly and carefully.
Please perform this additional step.
click on start >> Run
In Run box type services.msc /s and press enter.
You will see a services page.
Search for print spooler
Double click on print spooler.
Make sure that start up type is "AUTOMATIC"
CLick on stop and then start the service.
Then start installing the printer software, this should fix the issue.
Have a great day!
Mar 25, 2008 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 1350 printer
i cannot re-install my hp 1350 all in one scanner. i have uninstall and re-install the printer driver was unknown. how can that be possible even i dont have the cd that comes with it.
Feb 02, 2008 | HP PSC 1350 All-In-One Thermal Printer
X3470 printer installation
One of the most possible reason is related to Print Spooler service. Please check the "Print Spooler" service if its turned on. if its not you can turn it on. Here is the way to go Services screen
  • go to start menu then run and type "services.msc" then hit enter
  • locate the Print Spooler service in the services list
  • Change turn it on  switch to Automatic mode
Try reinstall
Good Luck
Dec 29, 2007 | Lexmark X3470 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
139 people viewed this question
Ben Johnson
