Question about Car Audio & Video
Need a wiring harness for Scott's gx1642 Where might I find that
I have a Milwaukee circular saw, 6365, and am replacing the switch. Need a wiring diagram!
Scott,
What is the serial number on your saw? I need that to make sure I get the correct info for you.
May 30, 2015 | Milwaukee Tool Saws
2003 Chevrolet Silverado LS 1500HD 4x4 doesn't engage the front diff
That model does have issues with poor grounds and corrosion at the firewall harness plug. I would insure the frame ground is good (Wire connector is at frame rail under drivers door area) and the harness connection is free from corrosion. Wire harness abrasion is also an issue...insure the insulation on the wires is intact and not allowing a short. If all that is good....the module is most likely at fault. The best way to test is with the GM factory tester....pay the fee...have it diagnosed and then you can renew the defective part instead of "guessing" and throwing parts at the problem.
Scott, Porsche Master Tech. 35 years
Jan 12, 2014 | 2003 Chevrolet Silverado 2500HD
Different or additional harness needed to install a Kenwood kdc 255u radio/cd player in a 2005 Scion XB?
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
Hope this helps..
Cheers,
Scott
Jan 17, 2013 | Kenwood KDC 255U - radio / CD / MP3 player...
My power locks power windows and power drivers seat all quit working at the same time on my 2006 nissan altima. Checks all the fuses? Any help please we have rain moving in. If it could be a relay, which...
I have seen this common problem on several Altimas. You have a wire that has been pinched in your power seat that is frayed and grounding out on the seat frame causing the circuit breaker in the BCM to trip. U will need to remove the drivers seat from the car, Use a screwdriver to pop off the seat adjustment knobs, the pop off the plastic cover from the seat switch. There are two phillips head screws holding the switch to the seat. It is necessary to cut the seat material a small amount to access the screws and remove the switch. U will need to unplug the switch from the bottom side of the seat and unclip the wiring harness from the seat frame in order to remove the switch/wiring harness assembly. Once removed you will see the chafed wire. Simply cut the insulator that covers all the wires back far enough to repair the wire. I normally take a small piece of vacuum hose, split it down the middle and put over the chafed wire. Tape everything up with some electrical tape. When putting everything back together, re-route the wiring harness to a different location so it doesn't get pinched again. Re-install the seat and enjoy having all of your power options working again. If you need any more info on this or some helpful pics, let me know. Have a good day!
ASE Certified Auto Tech
Scott Day
Mar 28, 2012 | 2006 Nissan Altima
My 2000 dodge neon at red lights or stops will start to sputter or **** like its going to stop i've just about put everthing new on it new head gasket,spark plugs, plug wires, distributer, battery and it...
Scott, this might sound strange but check the wiring harness just in front of the AC compressor, sometimes, this wiring harness will come loose from it's tie down and start rubbing on the AC compressor pulley causing all kinks of electrical glitches intermittently. Remember, your Service Engine Soon light is for Emissions only, it will stay on only if your car is polluting. Good luck, Gary
Jul 26, 2010 | 2000 Dodge Neon
Will a 1990 geo tracker engine direct fit into a 1987 samurai? Scott
you will need an adapter kit (from- trail tough, low range off road, rocky road outfitters...) and the wiring harness from the tracker
I’m happy to assist further over the phone at https://www.6ya.com/expert/jerry_612d8419f8984578
Aug 27, 2009 | Suzuki Samurai Cars & Trucks
Face inop lights work no display
check the wiring harness most new headunits have a wire for ignition but not many cars have it by joining this wire to the live should sort the problem
Aug 12, 2009 | Kenwood KDC-MP435U CD Player
Wiring for stereo in 94 ford explorer
Sounds like you have the Premium Sound system. The main power plug is long and probably black, the other plug is square with a grey round cord coming out correct?
You can either take your power harness back and get the correct one ( a little more expensive) or run ALL 4 sets of speaker wires back to the right rear quarter panel. That is were the OEM amp is mounted and taking that panel out requires you to remove the top and bottom tailgate trims, a dozen screws, the seat belt D-ring and 4-5 plastic push clips that will probably snap off...:( Also, this will not make the OEM subwoofer work.
From 20 years experiance in this biz, save the time, spend the extra 30$ or so and just buy the correct connector. Check MetraOnline.com and search there.
Scott
Apr 16, 2009 | Dual XDMR7710 CD Player
L300 Audio Wiring Diagram
http://www.installdr.com/Harnesses/Mitsubishi-Wiring.pdf<br />pls rate<br /><br />
Oct 27, 2008 | 1990 Mitsubishi Minivan
Radio connection Pioneer vs Subaru Forester
I would like to refer you to a reputable car audio dealer.
If you have NOT yet CUT THE FACTORY HARNESS, DON'T!!!!!!!
Airbags are nothing to take lightly...
I HIGHLY RECOMMEND a wiring harness adapter from a reputable source such as METRA, Scoche, or Pozitive Connections. Every wiring harness adapter changes the colors at the "pioneer side" of the harness to color match the PIONEER RADIO. All you have to do is color match, plug and play.
HOPE I HAVE HELPED.
Scott
Sep 27, 2008 | Pioneer DEH-2800MP CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
