How to wind bobbin with pictures
Singer indicates that the 2430 to the Merritt 2404. The Merritt 2404 manual is available on the Singer support site: https://www.singer.com/support . The current link to this manual is https://www.singer.com/sites/default/files/product_manual/9bb8bc029ac33374a16f6ef37fdb37c14c7a8356_0.pdf . To wind the bobbin, make sure that the needle is up and lift the presser foot. Hold the hand wheel with one hand and keep it from moving. With the other hand, loosen the knob in the center of the hand wheel by turning the knob towards you. If the thread is not already on the spool pin, place it on the spool pin with the thread retaining slit to the right. Put the spool holder on the spool pin so that it holds the spool firmly.
Next snap the thread through the thread guide post and open the top cover. (If you have been sewing with the spool, unthread the upper thread back to the guide post.) Wrap the thread the bobbin tension disc going clockwise as you look at the top of the disc. (Bring the thread in front of the machine as you move to the left; then bring around to the back as you bring it to the bobbin winder.) Bring the thread up through the hole in the bobbin. Place the bobbin on the spindle with the hole up. Move the bobbin winder to the right. Hold onto the thread above the bobbin while you start winding the bobbin. After a few turns are on the bobbin, you can let go. After the bobbin is full (or full enough for your task), clip the thread and remove the bobbin. Move the bobbin winder to the left. Tighten the knob in the hand wheel by turning it away from you while holding the hand wheel.
I hope this helps.
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
SOURCE: singer 2662 winds bobbin only half full.
there is an adjustment on the bobbin winder. Just bend the little spring flap that rides inside the bobbin while winding. Bend it up a little. The flap being pushed up is what releases the shut off
SOURCE: Singer/merritt 2430 bobbin fill
If you lift up the thread holder, the bobbin holder is inside. Loosen the hand guide to stop the needle from going up and down. Pull the thread around the top thread guide and back into the bobbin holder. Thread the bobbin and move the bobbin over so the guage is "inside" the bobbin. As for the manual, the Singer Merritt 2404 is applicable to the 2430 if that helps.
Google.com found a Manual for sale online, but you requested a free manual.
