I can hold the agitator and move the tub side to side or front to back and it will hit the casing
SOURCE: maytag washer bangs during spin cycle
My maytag washer wont spin the water out during it's final spin on the heavy cycle, but if I move the button to another cycle like delicate or medium it will spin out the water during that final spin. there is no hose blockage, the water does pump out during another setting just not on the long heavy cycle. Model lat8714ae........ao17894ko...any ideas anyone????
SOURCE: washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
SOURCE: whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
SOURCE: Washer tub bangs when in spin cycle
Try running a smaller load. Sometimes when you put too big of a load in the washer it will not balance properly.
Sometimes when you have this problem, stop the machine and manually redistribute the clothes so that they look like they are even in the tub and start again.
There are also springs that center the tub in the machine and this could be a problem, but it is not as likely.
There are a lot of distributors of parts online if you need to order parts.
SOURCE: I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
