Question about Jenn-Air JGW8130A Electric Single Oven
Jenn-Air Electric Oven - F-1 Code
Help! Our oven keeps beeping at us and giving us an "F-1" message. We're about ready to shoot it, or run away from home.
  • 3 more comments
  • Anonymous Dec 10, 2007
    Went to an aapliance dealer. They told me that the f1 code was the clock mudule. Paid $135 for part and replaced it. Worked for about two weeks and then started to beep again. Still searching.
  • Anonymous Dec 26, 2007
    Jenn-Air W131W that shows a code F-1. This happens more often that now but we have experienced times where it didn't happen. Must turn off at the breaker to get it to stop. The second problem is that the tempature is approximatly 100+ degrees lower then indicated.
    What parts are needed for corrections?
  • rgscan Jan 03, 2009
    I have owned a similar Jenn Air oven since 1993 - every 1-2 yrs our front panel module goes. The symptoms are an F1 code in the display and a very annoying constant "beep" (which always seems to occur in teh middle of the night). I have written and spoken to Jenn Air about this problem (it is the most unreliable appliance we've ever owned) and they ignore the possibility of it being a design fault. This code is mis-reading a fault condition which causes the alarm. I'm looking for ways to disconnet the speaker - any clues?
  • STEVEN LITTLE Jan 25, 2009
    Same F-1 beeping problem - I have to shut the circuit breaker off. Also
    take forever to cook anything - I think the oven temp is much lower than
    the readout states.
  • Anonymous Feb 01, 2009
    i so love google.... thank you for being there... now my headache will hopefully go away after we reset the circuit breakers!
    Hubby said Forget it... it is time for a  new oven
You can disconnect the beeper so its not so annoying. turn oven off at breaker first. pull out oven a little so you can get at the top 2 screws on each side. The speaker is between the boards on the display module.
look for a red wire connected to a gold disc like speaker. remove this wire and you won't hear the beeping anymore.
Posted on Oct 06, 2009
Same problem here - buy a new oven.
Posted on Dec 26, 2007
Top electric oven will show an F3 error after being turned on and will beep. Botton oven works fine. Jenn Air electric oven model JJW927AAW. Serial number 11993640WO
HI thanks for your question.. code F3 says to replace the oven sensor, located in the oven. top left corner. Replace the oven sensor. Thanks
Dec 17, 2010 | Jenn-Air Ovens
Jenn Air oven keeps beeping F2 and the upper oven broiler won't shut off. We do not have a manual. Please help!!! (925) 672-1279
Sounds like a welded relay on the control board. You can replace the board or have the board repaired for much less expense.
Feb 20, 2010 | Jenn-Air JJW8230D Electric Double Oven
F2 code
F-2 error for jenn-air means the oven is to hot, it could be the oven temperature sensor is faulty, or the relay board.
Mar 29, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Beeping and F7 when cleaning
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn Air double oven keeps beeping
The problem is with the faulty relay board or wire harness harness.
There are no home remedies for this problem.The only solution is to get it repaired.
Sep 17, 2008 | Jenn-Air Electric Double Oven
lower oven gives Fr code when turned on
Jun 23, 2008 | Jenn-Air JJW8527C Expressions Collection...
Jenn-air Oven Model W256W
just scroll down on this e mail and in the comment box you can answer my question
Feb 14, 2008 | Jenn-Air JGW8130A Electric Single Oven
Jenn-Air JGW8130A Electric Single Oven Logo
1,000 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
