The user name and or password you are typing in is wrong.
The default user name for d-link routers is admin with no password. If that changed, you can also try admin for the password.
If you aren't having any luck, it is possible that someone has gotten into your router and changed the password. To reset the router to factory, press and hold the small reset button on the back of the devide for ten seconds.
Then try to connect again.
Good Luck
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
Two windows 7 PCs connected to DLINK DGS-1005D gigabit switch. Switch is commected to DSL-G604T...
(More)
Two windows 7 PCs connected to DLINK DGS-1005D gigabit switch. Switch is commected to DSL-G604T wireless modem/router (old gen1 model). All works fine for a while then internet access speeds for one computer on the switch drops to about 10% normal. Plugging this PC directly to the router stops problem and works fine - but then i loose the gigabit speed link with the other PC.
