When inserting a vhs tape, the unit powers off.
    Sergeant:
  • 209 Answers
Possible motor short or open wire causing unit to shut down. Replace it.
Posted on Apr 23, 2019
SOURCE:
SOURCE: VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Posted on Nov 07, 2007
ctf1800
  • 4402 Answers
SOURCE: Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Posted on Dec 04, 2007
  • 883 Answers
SOURCE: vhs tape gets chewed
Dear William,
the rubber belts and rubber capstan need cleaning/conditioning. you can attempt this with alcohol swabs and if you find rubber conditioner (in the past was easy to find in audio supply stores) apply some of this also. if this treatment does not solve, then may need new rubber belt kit. good luck.
Posted on Dec 27, 2007
  • 3 Answers
SOURCE: VHS won't play, sounds like tape will load then power shuts off.
This is similar or identical to another post, but here is an answer...
Hi, I have a solution you can try.
I had exaclty the same problem. When I tried to play a tape it would load (However, I recall I had to push hard to get the tape to be accepted, which is part of the problem) but would shut off after about 12 seconds, then when I powered back up the tape would eject. Finally I took the unit completely apart and attempted to use it with the covers off. Lo and behold, I found I could play a DVD on the unit without the unit powering off, but only if the room lights were on! If I tried to play a tape it would shut down the unit. So that led me to diagnosing the infrared loading and reel sensor circuits.
Background on that is there is an infrared LED that shines up through a plastic light pipe lens. The light from that LED (you can't see it) should shine on two photodiodes that are on either side of the tap mechanism, plus down through a gear with holes in it on to the reel sensor. When there is no tape inserted the two photodiodes will be illuminated and have about 0.2 volts across them. When a tape is installed the light will be blocked and the voltage goes up to above 2.5 volts across the diodes. You have to check this with the room lights dim as the diodes will respond to that light. When you block the light on either side of the plastic light pipe with your finger (with the unit disassembled) you should see the load motor engage, and it will back off when you take your finder away. For some reason in my unit the light from the LED was insufficient to turn on one of the diodes, and also to pulse the reel sensor when the gear turned. That could be due to component aging, or even if the light pipe started to cloud due to age, I don't know. However I was able to get the thing working...
In short I got the unit working by adding 3 resistors.
To do this you'll have to remove all the covers and remove the main PCB from the bottom chassis, unplug the power supply from the PCB, and the two ribbons going to the DVD unit. But you won't have to take off the VCR assembly, which is a pain. You just need some basic soldering skills, and remember where all those screws go...
First, I adjusted the voltage across the right-hand side load sensor diode to get the diode to switch on and off. I recall that I added 1meg across the diode. So the voltage then went from about 0.5v up to 2.8v from light to dark condition.
Second, I increased the current to the IR LED. I added a 330ohm resistor across the feeder to the LED. I recall that was R511 and was originally 220ohms. That was not quite sufficient to get the reel sensor working reliably. I didn't want to stress the LED by putting too much more current through it so looked for another idea.
Third I added 56k across the reel sensor diode to bring the voltage across it down so it would switch on and off as the reel sensor gear turned.
I now have a tape playing continuously in the unit and it seems ok for the time being. Hope that might work for you too.
Craig Townsend
Posted on May 26, 2009
  • 4234 Answers
SOURCE: A VHS tape is stuck in my TV/VHS combo unit.
I'm sorry to say that the solution as stated is not correct. This condition usually occurs because of belts that are slipping. In order to remove the tape, some dis-assembly is required. If you have not done this in the past, I would not suggest that you attempt this repair. This repair should cost about $10 in parts plus labor. It is possible that the IR LED is defective as well which can also cause this. This is a common failure and should be a simple repair for any shop.
Dan
Posted on Jun 04, 2010
Testimonial: "This helped also. Don S"
When inserting vhs tape, the player pulls the tape from inserted vhs
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
Mar 22, 2014 | Samsung DVD-VR325 DVD Recorder/VCR
When inserting vhs video tape into Sony 6 head video cassette recorder tape will not play and will not be released by recorder
Please reset your unit.Just unplug all the cords from the back of the unit and the power cord as well for 1 hour after that reconnect the cords and turn on.the tape will come out.
Let me know the result
Oct 13, 2008 | Televison & Video
Err on display when insert tape, no functions work.
Two things. First there is some damage to the tape transport mechanism. Only a good look around will confirm this. Secondly a faulty mode switch.
Jan 14, 2013 | GE VG4250 VHS VCR
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VHS tape is stuck in the VCR. Tape will not eject, will not play or foward/rewind. The unit has been working just fine with no problems. The VHS tape has been inserted into the machine to record daily...
assuming you have power to the machine , i would suggest the ejection drive belt has stretched , 2 choices here , take it somewhere and get it fixed or unplug it from power supply and remove the top casing yourself and have a look.
Jan 29, 2018 | Toshiba SD-V291 DVD Player/VCR
I have video cassett size 8...I dont have the camcorder to watch it, I need to transfer it the regular DVD or any size...please help...thanks
look online or in some electronic stores for an adapter--the tape fits into a vhs format case and the vhs adapter is inserted into player theirs a vhs play adapter made for just about all compact tape units
Apr 26, 2010 | TDK 8mm MP 120 Minute Premium Camcorder...
No video output when played on vhs
try cleaning the cylender head of your vcr you can do that by opening the unit or buying vhs vcr casset cleaner....
ps : check if you have to switch between tv and vcr via remote , and when you insert the vhs tape you are able to rew and frw and press play normally...if these are ok usually its a little dirt onthe cylender head....hope this helps...
Jan 01, 2009 | Panasonic DMR-E75V DVD Player/VCR
No remote for Goldstar 8mm VHS VCR recorder player
I have an extra remote to that unit if you would like to buy it. shesteasing@yahoo.com
Dec 06, 2008 | Goldstar GVR-DD1 VHS VCR
Dec 04, 2007 | Sony SLV-D300P DVD Player/VCR
VHS player stops
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
