Question about Maytag Dryers
Maytag dryer center, wanted to refresh cloths , pushed sensor dry button, hear click, like breaker fliped, then no lights on panel. breaker good fuse panel. unplugged dryer 15 min. no panel
Sounded like breaker tripped. no power
3 Suggested Answers
SOURCE:
heatman101
  • 43501 Answers
SOURCE: "On" button does not turn on dryer selections
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 21, 2010
richroth
  • 9472 Answers
SOURCE: 9 year old dryer would
The moisture control sensor will determine the amount of moisture in your clothes and find out how long the drying time needed is.
If this does not work, you cannot efficiently dry your clothes. Sometimes, the dryer will also overdry your clothes. The first thing you need to do is to check the ventilation of your dryer. Slowly pull it forward from the wall where you have installed it. Unplug the dryer first. Carefully remove the exhaust hose.
While the exhaust hose is detached, plug the dryer again and run a short drying load. If it is working, there might be something clogging our exhaust hose. Lint may have accumulated in the dryer. You need to remove clogged particles by using a shop vacuum.
There are a couple of reasons why you are experiencing one of the most common Maytag Neptune problems-trouble heating up. The first one is because of a faulty thermal fuse. If the thermal fuse is switched on or off incorrectly, you should have it replaced.
You can purchase this part for $10 per piece. The thermal fuse is responsible for regulating temperature inside the dryer. If it senses that the temperature is turning up too much, it aborts the operation. As a result, it will not completely dry your clothes.
Here is a link to the thermal fuse if you find this is the problem.
Posted on Dec 04, 2010
No heat in my gas dryer, ignitor replaced, and sensor dry level does not light? I miss my dried clothes!
It sounds like your thermal fuse blew which is very cheap and easy to replace. Unplug your dryer and gain access to the back panel. Remove the panel and locate the thermal fuse. It is usually a white piece of plastic about 1/2" wide and 1 1/2" long with two wires attached to it. (Generally located near the bottom left as your looking at it) Unplug the two wires and unscrew the screw holding it in place. Replace it with the new one and reassemble everything. Good luck!
Apr 10, 2017 | Maytag Neptune MDG5500AW Gas Dryer
Dryer has warmth but clothes are not drying. vent is not clogged, temp set at regular,drum is turning What could be the Problem?
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Gas Dryer---
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Sep 25, 2010 | Maytag PYE2300AY Electric Dryer
Maytag MCE8000AZW Neptune Drying Center. Display
my bottom dryer the light dont come on or when i press start it wont start all i hear is a click...any solutions?
Jan 31, 2010 | Maytag Dryers
I have a maytag neptune gas dryer and out of a sudden it stopped heating. excellent air flow but no heat
OPEN THE DOOR, TAKE OFF THE FOUR SCREWS, REMOVE PANEL. CLOSE DOOR AND TURN ON MACHINE. LOOK UNDER AND YOU WILL SEE THE BURNER ASSEMBLY. IF THE IGNITOR DOES NOT GLOW, YOU HAVE A BLOWN THERMAL FUSE. IF IT GLOWS BUT WOULD NOT LIGHT UP, YOU HAVE A BAD RADIANT SENSOR OR YOUR HIGH LIMIT THERMOSTAT SHORTED OUT. IF YOUR THERMOSTAT HAS A RESET BUTTON, PUSH IT IN AND YOU WILL HEAR A CLICK, THAT WILL SOLVE YOUR PROBLEM. GOOD LUCK
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THRU IT IF NEEDED.
Jan 16, 2010 | Maytag Dryers
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
LER8858EQ2 electric dryer will not come on.
Thermal fuse on the blower housing is open. Take back off and the thermal fuse is near the blower outlet. It is white and about 2 inches long. Part number is 3392519
Dec 12, 2008 | Whirlpool LGV4634JQ Gas Dryer
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
I get e01 on ge dyrer panel
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE;
Aug 22, 2008 | GE DCVH515EF Electric Dryer
Dryer
either door switch or thermal fuse on rear of unit Exhust duct check those and let me know..(Fuse is white with 2 wires)
Feb 18, 2008 | Dryers
Dryers Logo
35 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
