Question about The Audio Players & Recorders
My Kubik Evo player is suddenly dead.Cannot access it in any way.It will not react to charging and because it will not turn on I cannot access files either.
This was bought new several months ago and I really liked it I have had MP3 players for years and this was the best so I would like it back
  • The Master
  • 468 Answers
Hello Tom, control the battery, verify that it is charging, if you do not achieve
observe anything, remove the battery and clean the power contacts and contacts for the player's battery, reinstall and check if there are signs of operation
Also check the charger or replace it with another one of similar characteristics
Good luck with the tests
Greetings Franco Dosil
Hola Tom, controla la bateria, verifica que esta cargando, si no logras
observar nada, retira la bateria y limpiale los contactos de energia y los contactos para la bateria del reproductor, la reinstalas y compruebas si hay signos de funcionamiento
Tambien chequea el cargador o reemplazalo por otro de similares caracteristicas
Suerte con las pruebas
Saludos Franco Dosil
Posted on Apr 19, 2019
SOURCE:
SOURCE: my mp3 player wont turn on.
hiya I have a sony bean too and it does exactly the same thing as yours, if you havent sorted it out yet all you have to do is look under the usb flap and you will see a reset button, push it gentally with a pin, it will work agauin and you wont loose all your music, hope this helps
Posted on Feb 03, 2007
simplemitch
  • 752 Answers
SOURCE: the battery will not charge. The player was bought 10 mnths ago
Test the voltage at the end of the power supply cord. perhaps the cord is broken or the power supply is dead. The output voltage should be listed on the adapter or by the DC input jack on the unit.
Posted on Sep 11, 2007
SOURCE: Isonic Snapbox mp3 player wont turn on or charge
get a new mp3
Posted on Jan 07, 2008
  • 4 Answers
SOURCE: Download from WAC7000 to Samsung MP3 Player
Hi !
I strongly suggest that you discuss WACS related issues in the Streamium Café (www.streamiumcafe.com). This is where you will find an answer to your problem (look for the WACHandler" threads where you will find a link to my application ;)
Cheers !
/Mathias
Posted on Feb 02, 2009
SpideRaY
  • 687 Answers
SOURCE: My Sony WALKMAN mp3 player won't charge
If it is a NW-A1000 I have a copy of the service manual please download it from HERE from deposit files..will be active until 29th November 2009, let me know if you need it for longer.
Goto page 9 section 4 TEST MODE.
1. Press HOLD to put the player in hold mode.
2. Hold down LINK and press in order UP, DOWN, OPTION, UP, DOWN, RIGHT, LEFT, RIGHT, LEFT, LEFT, PLAY/PAUSE, OPTION.
3. Press HOLD to turn hold off. You will now be in test mode.
4. Press RIGHT to display menu items
5. Press the UP,DOWN to select the POWER
6. Press RIGHT to select V CHK
7. Press the PLAY key START is displayed and all the power lines will be started.
TP9027: 1.10 ± 0.05 V T
P9023: 1.3 ± 0.1 V
TP9026: 1.8 ± 0.1 V
TP9031: 3.0 ± 0.1 V
TP9018: 3.0 ± 0.1 V
TP9028: 3.3 ± 0.1 VT
P9024: 5.0 ± 0.2 V
You can check these on the main board to see it all are present if one is missing this will be why your walkman wont hold any charge.
LOL
Posted on Sep 23, 2009
How do I fix my Kubik Evo 8Gb? The software doesn't work. The screen is black and I can not get access to the menu. My files are ok I can see them when I plug it to my computer. Thank you
Your electronics are ng. U might try to reset unit by doing a hard reset to see if that clears up the anomaly. If not, replacement, not repair, is in order.
Aug 27, 2016 | Kubik Digital Electronics Kubik Evo 8Gb...
Wont turn on when not plugged in. but will turn on if charg plug is plugged in and you turn on the power switch and unplug the charger it will stay on but wont play, keeps coming up format error.
Customer Reviews: Kubik Evo 8GB MP3 Player with Radio ...
www.amazon.com/Kubik-Player.../B0041MMMWW
Amazon.com, Inc.Find helpful customer reviews and review ratings for Kubik Evo 8GB MP3 Player with ... Con's - Wonder if some of these items can be fixed with a firmware update. ... Just push the main button (or any button) and it will turn on and function as usual. ... 2) Play while plugged in charging works with the wall charger, but still NOT ...
Evo won't charge via USB ' Android Forums
androidforums.com > Android Phones > HTC EVO 4G
Jun 29, 2010 - Whenever I plug in my Evo, I select Charge Only (or if I do nothing, it selects Charge. ... If I turn off my Evo it charges from the USB fine. ... Check your computer's stats... what does it say about its USB status when your Evo is plugged in or ... I had a problem a while back where it would charge via USB, but not ...
Dec 29, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
Songs just stop about 3 quarters of the way through and skip to the next one.
I had a similar problem when I tried to download non MP3 formatted files ,
make sure it is for the MP3 player ,
May 11, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
When I try to play a track I get a message "No files"
Try formatting the sd card to fat 32 before saving the mp3 files to it. Also try using a high quality low capacity sd card. Scandisk 8gb for example.
Jan 05, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
Deleting music from kubik evo 8gb
Select track to be deleted, press and hold the volume button, a box will appear asking if you want to delete, select yes and press the large centre button,it will then state file deleted .
Sep 28, 2014 | Kubik Digital Electronics Kubik Evo 8Gb...
How do I put MP3 files on Kubik Evo 4gb?
The easiest way is to plug it into a PC - any Mac, Linux or Windows machine will see it as a USB flash drive. Copy the mp3 files you want to listen to into the Music folder. The trick is when you disconnect - unmount the flash drive (or eject it if using Windows) and then wait for the Evo to switch from USB connect symbol to the charging symbol. If it does not change after 5 minutes, unplug it, flip the side switch to off, then back to on and it should be OK.
Aug 01, 2014 | Kubik Digital Electronics Kubik Evo 8Gb...
Why am i having transferring files problem with kubik evo
What are you using to transfer the files?
Attach the device to your computer using the USB lead
Wait for your computer to find the device
Then use Windows Explorer to drag and drop the files onto the device
Make sure the files are in a compatible format to the device
Once transfered power up the device and rebuild the Index of Music using the option under the music menu
Jun 22, 2014 | Kubik Digital Electronics Kubik Evo 8Gb...
How to put a playlist on a kubik evo
Try rebuilding the Music Index using the option under the Music Menu when the device is powered on
Apr 12, 2014 | Kubik Digital Electronics Kubik Evo 8Gb...
I have converted a film to the correct avi format/size/bitrate/audio..etc etc and tried every configuration and even contacted kubik. the film will not play due to unrecognised format
You can install the software off the Kubik site
AVI Converter Kubik Digital and this has the advantage of being set to the correct size for output (160x128) but I have had mixed success with this. Some files have worked fine, others just stall and the batch processing feature does not appear to work (at least for me) so I am searching for more reliable alternatives.
Oct 29, 2013 | Kubik Digital Electronics Kubik Evo 8Gb...
22 people viewed this question
Top The Audio Players & Recorders Experts
meowwl
Level 1 Expert
D. E. Hev
Martin van der...
Martin van der...
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
