I adjust the low speed screw but it don't help it to idle what i need to do to fix the problem?
SOURCE: nissan ga15 engine idle adjustment locations
The idle speed is computer controled, it is not adjustable, you most likely have sludge in the throttle valve and the idle speed control air bypass valve, clean them with carb spray with the engine running.
SOURCE: Idle Adjustment Screw Location on 96 Civic
your idle can not be manually adjusted. it is controled by the ecm via the throttle position sensor on the throttle body(tps). you have to have a diagnostic scanner to interface with the ecm to adjust the idle. most service shops have this equipment
SOURCE: Need to adjust fuel and air mix to start trimmer.
Hello gwturley201:
I am Including the Carburetor Adjustment File Also.
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holding it to the Carburetor Body.
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade or for Chainsaws and Trimmers; they Operate without Bogging Down. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: idle speed adjustment
the ecu drives a unit called an idle airspeed controller.if there is a vacuum leak,the computer will have the idle speed too high.
the IAC is a motor driven valve that controls airflow into the throttle body.it is common for idle speeds in the range of 1400rpm instead of 800 in this situation.
check the air filter,the throttle body cleaned,and the IAC has to be free moving.
also make sure that your coolant temperature sensor is accurate or the computer will think the engine is cold and keep the idle really high.
