Question about ASUS VW192S Monitor
A white line across my screen
I brought my monitor at a computer show in nyc and a white line across the screen appeared days after using the monitor. It hasn't dropped or anything and this line is starting to get on my nerves. I have the reciept and everything I just don't know where to go from there and i'm wishing I just brought my monitor in a regular store.
Re: a white line across my screen - ASUS VW192S Monitor Computer Monitors
Check vertical deflection
Posted on Feb 22, 2008
I got the same problem, I'm going to return it to the store today...
Posted on Dec 14, 2007
0 characters
3 Points
AOC monitor black screen how do I fix it?
I have a couple AOC i2353ph monitors. One day, one of them booted up with a single vertical white line moving slowly back and forth across the screen that kind of looked like a scan or radar. Once I reset the monitor from the OSD it went way. Use "Extra > Reset" from the monitor menu.
Oct 22, 2013 | AOC 917Sw 19" LCD Monitor
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computer Monitors
AOC vertical white line moving across the screen
I have dual AOC i2553ph monitors. One day I came into work and notice one of them had a single vertical white line moving slowly back and forth across the screen that looked like a scan or radar function. I reset the monitor from the OSD and all is well again. Use "Extra > reset" from the OSD on AOC monitors.
Jan 31, 2012 | AOC Computer Monitors
(external monitor AOC LM765 flickers white lines) My laptop screen is damaged. I plugged an external monitor (AOC LM765 via RGB), works fine for the past three days but suddenly ghostly lines appear. Any...
Hook up that monitor to another laptop or computer. If it works then its an issue with the vga port on your laptop. If the monitor still shows those lines then you know for sure the monitor is bad and it will have to be replaced.
May 15, 2011 | AOC LM765 (Silver) 17" LCD Monitor
Screen Works With One Computer But Not This Mine
Soundes likw interference do you have electrical high lines near that area.
Feb 13, 2009 | Gateway FPD1765 17" Flat Panel LCD Monitor
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
Thin line across computer screen
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Mar 08, 2008 | Gateway FPD1975W 19" LCD Monitor
White screen with thin black line
it is the problem with the lcd itself just call the customer care they will be replace it.
Sep 05, 2007 | Samsung 710V 17" LCD Monitor
Lacie 19" Electron Blue - Black screen with a brilliant white line across
I have 2 of these monitors and have this problem. I was so frustrated turning the monitor off and on until the white line disappeared that one day, I punched the screen. And it worked! So now whenever this happens (about once every other day) I use my palm and smack the lower left corner of the monitor until the white line disappears. I like the color on these screens so I don't want to replace them until I have to. I will NOT buy another Lacie though.
Sep 13, 2006 | LaCie Electron 19" CRT Monitor
ASUS VW192S Monitor Logo
1,008 people viewed this question
Top ASUS Computer Monitors Experts
 Mike M
Mike M
Level 1 Expert
Level 1 Expert
Are you an ASUS Computer Monitor Expert? Answer questions, earn points and help others
