Question about Lands Phones
Hey! How do I set wake up calls on KX-T7630? - Lands Phones
SOURCE:
  • 9 Answers
SOURCE: setting the time on the panasonic KX-T7630
This is a PBX system, correct? If so, the fastest way would be through the PBX control computer. If you have a Panasonic TAW series PBX, I really like the AbleComm websites, search for your model PBX there.
Posted on Dec 06, 2007
  • 6 Answers
SOURCE: kx-t7630 product spport
This is how I did it:
1. Press the 'Program' button 2. Then dial ** (star, star) 3. Enter the password (usually 1234) 4. Press 'Next' until you get to 'Ext Name' 5. Press 'Enter' 6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is) 7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters. 8. Press 'Enter' then you are all done... pick and hang up the handset.
Posted on Feb 12, 2008
SOURCE: Conference call
What good is a website where people don't post the solution to their problems once they've figured it out?
Posted on Jun 18, 2008
cnavarro
  • 2460 Answers
SOURCE: How do I change the language on my panasonic kx-t7630
Press the left button under the display (PROG in English) dial 021 STORE (4th soft key).
Now the buttons say PROG :-)
Carl
Posted on Jan 10, 2009
SOURCE: how do you set the time
To change time on the KX-T7630 switchboard (using the TDA 100).
Press Progam or pause
Enter **
Enter your system password.
press cursor down one level - you will then see set date and time.
To exit the programming mode at anytime, lift the handset.
Hope this helps.
CM
Posted on May 20, 2009
We have a Panasonic KX-T7630. I would like to divert calls to a home number? How do I do this? Cheers Linda
Here's the manual. I don't know how to do it personally. http://www.ask-tsc.com/pdf/KX-T76xx.pdf
Also have you considered setting up a google voice number? It's free and has numerous cool functions, like call forwarding, like you want to do with this phone.
https://accounts.google.com/ServiceLogin?service=grandcentral&passive=1209600&continue=https%3A%2F%2Fwww.google.com%2Fvoice&followup=https%3A%2F%2Fwww.google.com%2Fvoice<mpl=open#identifier
Nov 15, 2016 | Panasonic KX-T7630 Corded Phone
How do I set the FWD/DND to ON for Panasonic KX-T7630?
What is the model of the PBX It is done on the PBX through the phone not on the phone
Mar 11, 2014 | Panasonic Lands Phones
How do I get my panasonic kx-t7630 to ring more than 3 times before going to my voicemail?
If you've set call forwarding from the set, try dialin *713 and a 2 digit number from 00-99. It's the number of seconds before the call forward and a ring cycle is approximately 6 seconds, so start with 24 and go up from there.
There's another feature that will work against you, and that's the transfer recall time. It may be set to 20 seconds, so you will never forward before the recall timer. It's set on a systemwide basis.
Carl
Sep 16, 2010 | Panasonic KX-T7630 Corded Phone
How do i divert all calls from the kx-t7630 to a mobile?
You must subscribe to you Landline Supplyer for 'Call Divert Services' If Say you already Subscribe to BT.
The Proccess is access line... the on the Keypay dial... *21* (then The No; to be Diverted To) then confirm by pressing the # Key. Wait and the No; will be repeated to you.
To take off call divert access line dial #21#
When 'Call Divert' is set you will receive broken dial tone. through the Handset.
(Like a Siren)
Jun 28, 2010 | Panasonic KX-T7630 Corded Phone
HOW TO SET UP WAKE UP CALL
Panasonic calls the feature Timed Reminder if the staation user/guest is doing it, or Remote Wake-Up call if the console classed as operator is doing it. Both use a *76 code.
For the user, it's *7601 HHMM (x) 0/1 where HHMM is either a 12 or 24 hour clock, depending on system settings and the (x) is needed if a 12 hour clock when 0 is AM and 1 is PM then 0 for once and 1 for daily.
From the console, it's *76*1 EXT HHMM (x) 0/1 with the same explanation as above.
An OM is attached. Your instructions begin on page 125 and 133.
http://www.public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
Carl
Dec 19, 2009 | Panasonic KX-T7630 Corded Phone
Instruction on how to divert incoming calls to a mobile.
hey c'mon please let the receptionist go after you have finished , why you want her with you?
May 20, 2009 | Panasonic KX-T7630 Corded Phone
Night switching for KX-T7630
You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
Carl
Sep 09, 2008 | Panasonic KX-T7630 Corded Phone
I Need Help
hi sir
go to the settings>
advanced settings>
answer machine > enable.
it work's thank u. sir
Sep 03, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic phone kx-t7630
Sorry I couldn't up load the manual for you but here's the link for you: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Business-Home-Systems/System-Phones/Digital-Hybrid-IP-PBX-Phones/model.KX-T7630 You'll find all the programming settings on Pg 9. You'll need your "Pin code". I could not find anything on how to clear it if you forget it. You may need to go to a service center or call one. Good luck
Sep 08, 2007 | Panasonic KX-T7630 Corded Phone
Lands Phones Logo
23 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
