SOURCE: olevia 232-s13 32"
Just talked to Cust Supp, on the back you will see 6 round holes around the label. The screws needed will be 6mmx12mm. I have to do the same tonight. good luck
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
SOURCE: LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Testimonial: "Thank you! We'll head to Lowe's tomorrow to pick up the appropriate size screws. We just moved into a new home and they left the wall mount up for us, but did not leave any of the extra screws that went with the mount. Thanks again! "
SOURCE: we have a LC427SSX and want to mount it on the wall
The thread size is standard, just a metric standard. To attach the Sylvania LCD427SSX to the wall mount bracket you'll need (4) metric 8mm machine screws with a 1.25mm pitch. You'll find them at your favorite neighborhood hardware store with the designation M8 1.25x40mm. (40mm long...the 30mm would be to short)
SOURCE: Can't find screw size to
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
