Question about Radio Communications
I have a Wouxum KG-UV8D Plus. I have it on the wx channel and can see it is transmitting but don't get any voice. I'm sure it is muted somewhere. Don't know how to correct.
    New Friend:
  • 10 Answers
Check that R-DCS is off.
Posted on Apr 25, 2019
SOURCE:
Neto
  • 123 Answers
SOURCE: Cobra Li 6000-2 WX VP GMRS/FRS Two-Way Radio
This radios has a Reference Xtal, dropping the radio, could cause that the xtal goes out of frequency, this means tha the radios has a frequency error and the range of opearatin seems to be reduced or even null. With out knowlegement and equipmente, there is nothing that you can do.
Posted on Nov 22, 2006
  • 11 Answers
SOURCE: acertravelmate4000 got it used,don,t know how to
The volume may be muted. In Windows, look at the volume
control (speaker) icon on the taskbar. If it is crossed-out, click on
the icon and deselect the Mute option.
The speakers may be turned off. Press Fn-F8 to turn the speakers
on (this hot key also turns the speakers off).
The volume level may be too low. In Windows, look at the volume
control icon on the taskbar.
Fn-? Volume up Increases the sound volume. Fn-? Volume down Decreases the sound volume.
If this helps u let me know
regards
Posted on Jan 13, 2010
  • 1274 Answers
SOURCE: My radio just recently incurred
Hi, do you have the switch in CB mode ? Might be the audio chip, or the Finals, you will need a tech to do the job so he can set the ma on the finals. Hope this was helpful....My name is John. Thanks....good luck...
Posted on Sep 01, 2010
SOURCE: Casio SE-C300 - I have
I see, here is the Manual for he how to instructions on your Casio SE-300
See Link
It has all the details on how to change pricing and programming and allocating Plus prices for an End of the day readout.
I hope this will be Helpful.
Posted on Sep 01, 2011
  • 102366 Answers
SOURCE: UNIDEN DECT 6.0 don't have manual need to
Select the model of your Uniden DECT 6.0 phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to get the manual.
Posted on Sep 02, 2011
No audio transmit or recive
check your final for voltage, work your way from IC 1 on up then check audio transistor . Work your way through the transmit section then the receive section . Check your volume control ,make sure its working alright Just have patience and it might jump right out at you.
Dec 15, 2015 | Cobra 25 WX-NW-ST 40-Channels Base CB...
Factory reset wouxun KG-UV8D
Page 51 of the manual: https://hamgear.files.wordpress.com/2014/03/kg-uv8d-manual.pdf
Feb 24, 2015 | SainSonic WOUXUN KG-699E HF 66-88mhZ...
Cobra microtalk Cxt135C one radio seems to be muted, there is no sound coming from it at all -
Check to see if you have "tone squelch" or CTCSS enabled. It will only receive transmissions from stations that are transmitting the tone your radio has selected.
Oct 15, 2013 | Cobra MicroTalk PR 1100 WX (15 Channels)...
I am able to transmit but not receive
get another that only receives and no transmit.hook them up together .one on top of the other .I have a friend that did this and it actually worked
May 30, 2012 | Cobra 18 WX ST 40-Channels Base CB Radio
I have an almost new Midland 75-822 that the WX works fine on, but the CB doesn't seem to receive, or transmit. It operates normally, but no reception, and no evidence of transmissions.
you'll need a schematic and some knowledge. there a two diodes that control the rx and two that control the dx.Check them to make sure they are producing the correct power out put if they are not you should replace all 4
May 10, 2012 | Midland 75-822 40-Channels Handheld CB...
I get no squelch on my cobra 75 wx. I can't receive when somone transmits near me.
that's normal . If someone near you has more power then you he will walk all over your signal . You just might be doing the same to them.
Nov 28, 2011 | Cobra 75 WX ST 40-Channels Handheld CB...
Cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
May 29, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
Transmitting
Hello lstimpson,
You may have the CTCSS privacy code function enabled on one radio and not on the other. This function keeps your radio's received muted unless it receives a signal from another radio using the same privacy code. If you have Privacy Codes set for radio A but not for radio B you will still be able to transmit from A to B but when you transmit on radio B your signal will not be heard on radio A.
Make sure that both radios are set to the same privacy code or that the function is turned off on both radios.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 19, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
VOX Transmit is "pulsing". Also, no wx channel reception
check if the mic is not dirty, there is nothing that you can do to fix this problem.
May 04, 2007 | Motorola Talkabout T6310 (14 Channels)...
Radio Communications Logo
24 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
