Question about Panasonic PT-50LC13 50" Rear Projection HDTV
PT-60LC13 screen went black. red power light blinking 1x/second. hit power button starts blinking green 1x/second. after a while starts blinking red 1x/second and red "lamp" indicator starts blinking once every 5 seconds. replaced lamp. still black screen and blinking light situation the same as before. any suggesstions?
  • 4 more comments
  • tambe Nov 27, 2007
    my tv is the same problem , after 40 minutes working, it shut off itself with blinking red light then i restart, it shut off again . please,help me ...i am waiting for youre help..thank you.
  • CaptainRon Feb 05, 2008
    same exact problem with my Panasonic PT-50LC13, anyone fix this problem? what was the results??
  • Anonymous Mar 23, 2014
    5 blinks of red light won't turn on
    no power red light by power button blinks 5 times
  • Anonymous Mar 27, 2014
    replaced lifi get 13 red flashes indicating malfunction 16 so did what it says which is to wait a few seconds turn unit on again but same result....what is malfunction 16? thanks
  • Anonymous Mar 31, 2014
    I press Power (on set or remote) and the Power light blinks green for almost 2 minutes then blinks red for one minute and goes out. I can hear a faint hum inside while the Power light is blinking. No other indicators show.
  • 59 Answers
There are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
  • Rhonda May 26, 2012
    Where are the fans? Is it hard to get to?
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
We have a panasonic tv, model pt-60lc13, bought new in 2003. we use it less than 1 hr per day (last year we watched 2 movies). today, I turned the tv on, the green power light would blink slowly for...
This sounds like a power supply problem, or a vertical issue. The Panasonic sets are one of the best tv's out there and generally worth fixing, but it will need a tv technician to resolve the issues.
Jan 16, 2011 | Panasonic Televison & Video
Panason PT-50LC13 TV won't come on, light blinks green then red
Ballast failure is more that likley the problem. Is the lamp light blinking,...once every 5 seconds? Discontinued part and can only be purchased used or rebuilt. Rebuilt units are available, check Ebay. Have a service type person confirm problem before throwing good money after bad!
Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
We now live in Costa Rica. We have a PT-60LC13, and we have replaced numerous bulb assemblies over the years. Now we have a problem with the start up. When you turn the power on, the green light blinks...
I would suggest to read the info from this link and here and see if it compares to your DLP behaviour. The ballast part number is LSB3087A and is used by different models of DLPs. The repair kit is also available and much cheaper then buying the whole ballast assembly.
Good Luck.
Dec 11, 2009 | Televison & Video
Lamp problem or else?
You need to get the ballast repair kit #LSUC0002 and replace the parts to your ballast.
I have the exact same TV, did the above this past weekend, and the TV works like new.
You need to know how to solder though. It's not that hard.
Mar 14, 2008 | Panasonic PT-60LC13 Television
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic Projection HDTV Made 9/2003
Your lamp has most likely blown out. that is what happened to mine and once I replaced the bulb it worked just fine. this is one of the cheaper stores to find a replacement bulb,
Aug 29, 2007 | Panasonic PT-40LC12 40 in. LCD Television
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
886 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
