SOURCE: Antenna Power supply
First order of business is to check and see if the antenna is operating properly. If the wire in your harness is intended to power the antenna, connect 12 volts to this lead, and the antenna should go up (this needs to be done with the key in the ON or ACCY position). If the antenna does not go up, check the fusebox for a blown fuse. If the antenna does indeed go up, then you can scratch that off the list of possible problems and move on to the next step.
The Clarion should have a power input wire to keep the clock alive, and a power wire (normally of heavier guage) to actually power the radio. Make sure the radio operates when the key is in the ON or ACCY position. If the radio is operating, so far so good.
I'm kind of confused when you say there are two wires on the clarion... "power antenna turn-on" and "auto antenna". Are these both on the clarion? There should be a wire that constantly feeds the antenna with power (I would cal this one auto antenna). It should always be powered to 12 volts. The antenna should operate when the "antenna turn on" lead becomes 12 volts. Normally this ONLY happens when the clarion RADIO is on (ie: if you're listening to a CD, the antenna probably won't get activated).
After checking all this, if you're still having problems and if you haven't already done so, grab a DC volt meter and verify that the clarion power antenna turn on lead goes to 12 volts when you turn on the radio. If it does not, then there is an internal problem within the radio. If this lead IS going to 12 volts when it is supposed to and the antenna still isn't working, then my guess is that the antenna is malfunctioning.
Let me know what you find out... I'll keep looking at stuff from this end. Good luck.
SOURCE: kenwood kdc-415s
if there is no amplifier separate from the radio - the blue /white wire from the back of the radio goes to the solid blue wire on the harness attached to the car's plug. the orange wire is not supported by the kenwood radio, so make sure you tape it well- if your not using a separate amp also tape up the blue/white wire coming off the harness you have coming out of the harness to the car. if this helps you please give me a good rating- if not please e-mail me at [email protected] respectfully M. Merle
SOURCE: what wire do you use to hook up the power antenna
you are not putting a factor radio it not have that same colors . look at the wire diagram to tell which color to hook to car side
SOURCE: how do i wire the power antnna to my new jvc radio
its the blue wire/remote lead it does the antenna too
