Question about Car Audio & Video
What is the blue & gray lines that appear on the lower bottom right of my iPhkne 8 Plus when I reboot it?
SOURCE:
mistersony
  • 320 Answers
SOURCE: Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Posted on Oct 20, 2008
  • 4 Answers
SOURCE: screen appears blue
It's the Light Engine (also called an Optical block) -very expensive.
Posted on Jan 08, 2009
  • 65 Answers
SOURCE: blue line down right hand side of screen
If you are confident enough to open screen bezel and take out screen , then the second strap from right of your screen has a bad connection. theses cannot be repaired but as a tempory measure some duct tape across the connections will cure it, else replace the screen.
Posted on Mar 16, 2009
taminol
  • 62 Answers
SOURCE: A blue line , 2mm, appearing at bottom of page.
Hi Info39684,
It sounds like your Cyan imaging unit has gone down.
Have you thought of changing the orientation of your paper from A4 protrait to A4 landscape. If the blue line is at the bottom, changing the orientation should hide the problem. It's not going to fix it, and if you use A3 then you will see the line again. It's just an idea and you could save yourself £250 on a new unit.
Regards
Taminol
Posted on May 26, 2009
  • 58 Answers
SOURCE: my sony lcdtv kdf-55wf655 has a blue line across
Your screen has probably been bumped by something.
The line may be possible to be fixed by an engineer reseating the cables internally, but the patchy area is a pressure fault and cannot be fixed without replacing the complete screen.
You can get these patches on things like laptop screens too, where somebody has pressed a finger on them a bit to hard.
Posted on Apr 03, 2010
How to turn off monitor
1. Go to the desktop
2. Right Click
3. On that list, you should click personalize
4. In the lower right hand corner, click Screen saver (It's in blue letters)
5. In the bottom left hand corner of the window that just popped up, click "Change power settings"
6. In the left side of the new window, (It's in the light gray area) click on "Change when the computer sleeps"
7. Then from here you can set when you want to turn off the display and or put the computer to sleep after how long you have been inactive.
8. Remember to click the "Save changes" button to save what you've done.
May 25, 2014 | Total Gym Cyclo Trainer
I don't know how to multiply by a negative exponent. ex: 10(-8) ....the -8 is the exponent.
Press [2nd][,] to activate (EE) which appears on screen as a lower case E, enter the change sign (-) right of the [dot] on the bottom row of keys, enter the value of the exponent.
Ex: Enter Avogadro's number of Generalk Chemistry fame
6.02[SHIFT][,] (EE) (-)23
Here is screen capture of what it will look like.
Feb 23, 2010 | Texas Instruments TI-83 Plus Calculator
Stripes appear on monitor at bootup
I decided to change the background of my desktop and it works.
May 14, 2009 | Gateway FPD1760 17" LCD Monitor
Screen appears blue
Try Moving The Speaker You Have There Away From It?
www.Myspace.com/CrossRoadsToNowhere2007
Jan 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Toshiba LCD 37" with gray band and blue line
Unfortunately you are right it is the display panel going bad. You can either live with it or buy you a new tv as the panels usually cost as much or more than the tv. Sorry.
ladytech
Nov 01, 2008 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Wiring color code for xr-c5100
I am about to sell one on eBay - here are the connections from the installation paperwork and connector that I have:
Top row, left to right:
White - Front Left (+)
Green - Rear Left (+)
Purple - Rear Right (+)
Gray - Front Right (+)
Blue/White strip - AMP REMOTE (Max 0.3A)
Blue - ANT REM (Power Antennta Remote) (12V, Max 0.1A)
Red - Power (Accessory)
Black - Ground
Bottom Row, left ot right
White/Black - Front Left (-)
Green - Rear Left (-)
Purple - Rear Right (-)
Gray - Front Right (-)
BLANK
BLANK
BLANK
Yellow - Power (Battery)
One of the BLANKs is for the "Light Blue - ATT (attenuation for car phone)", but it is unclear which one. This wire is not on my connection block...
The circular BUS line to the right of the terminal block is apparently for linking to a CD/MD unit (cable supplied with unit)
The Blue 3.5mm socket is for the RM-X45 Rotary Commander (which attaches to the indicator lever)
Important notes:
If there is no ACC power line in the car, do not connect the red lead.
Ensure the power select switch on the bottom of the unit is in the B position, then press the RESET button (behind the faceplate).
This means that the display will be off when the unit is not in use - avoiding a flat battery risk.
(Posn A is for normal use, with red line on ACC)
The RESET buttom should be pressed after installation, before initial use.
Hope this helps.
Jan 08, 2008 | Sony XR-C5100 CD Changer
Wiring harness
This is on the case of the CD-335X
Line Out
gray (rear)- red/ right, white/ left
Power
Red- ign
Yellow- batt B+
Black- ground = neg12 volt
dark blue- power ant
orange- dimmer
Speakers
gray- right front (+)
gray/ black- right front (-)
White- Left Front (+)
white/ black- Left Front (-)
voilet- Right rear (+)
violet/ black- Right rear (-)
Green- Left Rear (+)
Green/ black- Left rear (-)
use 4 or 8 ohm speakers
Aug 25, 2007 | Jensen CD-335X CD Player
Vertical Lines all over then starts to move lines back and forth
you should first check all the cables inside the set to make sure they all are seated properly, check some other sources like a dvd player and see if it does it on a dvd, after that it is probably a defective main board
Nov 07, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
