My washing machine is showing Motor triac error what is it mean?
    Master:
  • Washing Mach... Master
  • 683 Answers
Normally a fault in the main board
Posted on Apr 22, 2019
SOURCE:
  • 26 Answers
SOURCE: Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
Posted on Nov 19, 2008
rickead1
  • 1998 Answers
SOURCE: My Whirlpool Duet Front Load Washing Machine is
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Posted on Jan 16, 2011
    SOURCE: my AW-1170S toshiba washing machine
    my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
    Posted on Aug 28, 2011
    • 6277 Answers
    SOURCE: I have a Bosch Logixx
    Same as 'F16', 'F34' stands for 'door lock (fault)' ;-0)
    This is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
    If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
    Thanks and good luck!
    John C
    Posted on Sep 15, 2011
    Testimonial: "Thanks - the engineer is coming later today. "
    erick69ha
    SOURCE: EF 2 error is showing
    it means that your using too much soap in your washer... the service manuel recommends that you reduce the amount of soap you are using.
    Posted on Dec 18, 2012
    Hi there, my Smeg WDF12C7-1 washing machine shows up error 11. Please help. Much appreciate.
    Smeg washer error code E11 means motor triac short error. The motor control triac is a small component mounted on the controller and is used to switch your motor on and off. Check the mains supply, the main control module and the main drive motor. It is also possible that the part is failing under load and needs replacing.
    May 02, 2018 | Smeg Washing Machines
    Zanussi zwn 6120 l washing machine Error code 5 red 1 green
    Your washing machine show the error code E51 what means faulty electronic (triac short circuited). Replace PCB.
    A good idea is to check the motor, which in practice can cause this failure (shor circuit motor winding) and sometimes is necessary to replace the electronics and motor and than is question profitability of repair.
    Dado
    May 07, 2015 | Zanussi Washing Machines
    My machine show error E51
    E51: Motor Power Triac Short-circuited.
    Oct 27, 2014 | Electrolux Washing Machines
    Why is my washing machine saying f o1
    F01 error code on most Hotpoint washing machines means "motor triac short - check motor and module connections".
    Dec 22, 2012 | Hotpoint Washing Machines
    Zanussi zdc67550w error code 51 - whats it mean?
    There are usually only two error codes beginning with E5 which are E51 and E52, which are "motor power triac short circuited" and "no signal from the motor tachometric generator" respectively.
    So if you have E50 displayed on a Zanussi or John Lewis washing machine it looks like a problem with the motor. However, the E51 "motor power triac short circuited" could be a fault on one of the PC boards as triacs are usually on printed circuit boards.
    This could have blown due to a short circuit somewhere else (like the motor for example). I would advise that an engineer is required if you can't see anything obvious with the motor.
    Hope this helps (remember to rating this free answer and leave a testimonial comment).
    Oct 13, 2011 | Washing Machines
    Showing F01 error code on readout? what does that mean?
    Hi.
    It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
    With Hotpoint F01 means defective triac or defective motor.
    Aug 18, 2011 | Washing Machines
    It says error code f-01. what does it mean
    Triac motor faulty or faulty motor. I had the same thing, technician said it is triac motor (150 pound) turn out to be the motor it self (about half the price)
    Feb 07, 2011 | Hotpoint Aquarius WD640 Front Load...
    Error message E50 shows when the machine is switch on.
    Zanussi washing machines can sometimes display error code E50. As John Lewis washing machines are currently also made by Zanussi some John Lewis washing machines can also display error E50.
    Unfortunately this is not a "proper" error code and is not listed in error code lists. It's part of the motor fault error code group and is apparently displayed to customers but when an engineer enters a special diagnostic display the "proper" error code will be displayed giving more information.
    However, there are usually only two error codes beginning with E5 which are E51 and E52, which are "motor power triac short circuited" and "no signal from the motor tachometric generator" respectively.
    So if you have E50 displayed on a Zanussi or John Lewis washing machine it looks like a problem with the motor. However, the E51 "motor power triac short circuited" could be a fault on one of the PC boards as triacs are usually on printed circuit boards. This could have blown due to a short circuit somewhere else (like the motor for example) - I would advise that an engineer is required if you can't see anything obvious with the motor.
    Jan 09, 2011 | Zanussi ZWF1430W Front Load Washer
    Washing Machines Logo
    37 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Marvin
    Marvin
