Question about Dryers
RemovING rear drums and breaks
Rear drums and breaks worn out.tryin to take the off to replace them
SOURCE:
  • 599 Answers
SOURCE: Seized rear brake drum on a 1997 Dodge Ram 1500
loosen emergency brake both sides..open wheel cylinder and let fluid run as you pry gently side to side in between drum adn shoe through backing plate /drum area to collapse the shoes some..... use wd40 or quality rust buster at center of drum /axle area to loosen grip of rust fused metal at hub to drum ..tap tap with hammmer around circumference of drum to dislodge adn loosen shoes from drum and drum from axle..good luck.. be patient work slowly
Posted on Nov 11, 2008
aborcass
  • 2651 Answers
SOURCE: change rear tub bearing
the nner tub and outer tub (rear section) need to be replaced,the bearing is mounted in rear section of tub, the entire unit is removed fromthe machine from the rear of machine in order to relpace. new pulley, nut, as well. not and easy job, and can be very costly paying for those parts.
Posted on Dec 04, 2008
martin538
  • 117 Answers
SOURCE: removing rear break drum from a 2006 chevy Equinox
You need to de-adjust your rear brakes and/or slacken off the park brake cable to remove the drum as the chances are the drum has a wear lip that the shoes are getting hung up on. ( first make sure there isn't a little retaining screw holding the drum on !..visible with the wheel removed)
Posted on Apr 07, 2009
  • 101 Answers
SOURCE: Trying to remove and replace rear brake rotors
First, make sure your parking brake is off.
Remove the rear caliper and then the brake pad housing. In the center hub of the rotor the parking brake shoes are located. The may need to be loosen first. There is a hole between 2 of the studs you need to align at the bottom. Look in the hole with a flashlight and find the star wheel. Use a screw driver to turn the wheel up a few turns to loosen the parking brake shoes from the rotor hub.
After that there are 2 threaded holes in the rotor near the studs you put two 8mm bolts in and slowly tighten each and it will pull the rotor off the hub. They rust up pretty bad so use penetrating oil on them.
Posted on Apr 11, 2009
  • 6 Answers
SOURCE: Rear disc brakes drag after installing new pads
Just did my rear brakes this weekend, Monday had a very slight drag. Noted that when I installed new pads I had to tap them on. That shouldn't be. When brakes are released, there should be enough play to allow the pads to back off the disc. Tonight, I removed the pads and filed down the ends of the tips that go into the top and bottom channels until I could install and remove them with fingertips, that gives them enough play to grab and release. Drag disappeared; the old girl ran like she should.
Posted on Feb 16, 2010
Can you check rear brake pads on 2015 ford ranger without removing wheel
no
it is necessary to remove any wheel to check disc pad thickness as they seldom wear evenly across the pad
May 11, 2018 | Ford Cars & Trucks
Break peddle squeak when I release my foot on my hyundai coupe 1.6 2001
moe than likely the rear brakeshave worn...in order to remedy, issue may be 1 of 2 possiblities... easiest is to adjust the rear brakes, however, that is only the rear "drum" brake application and not in rear "disc" brake. Most Accents I've worked on had the "drum" brake application. Typically no more than $40. to do something like that.
If the adjustment is not taking care of the squeal, then rear brake replacement is in order. Either shoes (for drums) or pads (for disc)
Jun 19, 2015 | Hyundai Cars & Trucks
Funny sound in rear wheels
it could be a few things either the breakes are worn disks or drums or the could be just rusty you can cure this by scraping the rust of if the breakes are ok possibley the rear wheel bearing creaking noises are usually just worn shocks or a broken spring could be a rattle hope this helps ivan
Oct 22, 2012 | Toyota Cars & Trucks
We overloaded the dryer and now the dryer is making a loud noise
The rear drum bushing or the front drum slides (or both) are probably worn out. You can view the rear drum bushing by removing the small plate in the center of the rear panel. Check if the center pin on the drum is touching the rear drum bushing housing. The rear bushing is made of plastic and is only about 1/16" thick, so look closely. If the loud noise is metal on metal at the rear drum bushing, replace the whole rear bushing assembly (drum center pin, bushing, and housing). Often, the front drum slides also need to be replaced. Check them before you buy the rear bushing. There are two at the bottom front of the drum and four more at the top front of the drum. You'll have to remove the front panel to check them.
Apr 27, 2010 | GE DBSR453EBWW Electric Dryer
The drum wont rotate, is it belt driven from the motor, if so how do you get in to change? cant get lid off
take the back panel off to get to ure belt, but first put ure hand inside ure machine n spin the drum if there is no strain wen tryin t spin the drum n the drum feels very light to spin ure belt has snapped if there is abit of strain u will need ure motor brushes changing
Feb 03, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Parking brake not holding
have you checked your rear brakes it sounds like there worn and needs to be replaced.
Oct 03, 2009 | 1991 Mercury Tracer
I need to know how to replace the rear brake drums.
First block the tires on the front of the car, front and rear of the tire. place the transmission in park, do not set the parking brake. Jack up the rear end, use jack stands on the rear. You should loosen the lug nuts on the wheels before jacking up.
With the truck lifted and properly supported, remove the wheels. This will expose the drum. Tap off the drum gently with a light hammer, the drum should pull off. Remove drum, it is a good idea to replace the shoes at the same time. This is done by removing the adjuster, the springs, then replace shoes as removed. Use brake cleaner on new drums before putting on, install the drum same as removed, put on wheel, lower truck and tighten the lug bolts. To adjust, turn star inside the rubber grommet on inside of drum. then you can adjust automatically by placing vehicle in reverse and apply the brakes until snug. This will get you done. Enjoy.
Aug 08, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Cannot remove rear brake drums
You need to back off the adjusters on the rear shoes to allow the worn drum to pass over the brake shoes.
A worn drum will have a unworn drum section on its outer edge where the brake shoes don't normally rub.
This must unworn ring must be able to pass over the brake shoes before you can get the drum off.
Two tools should be used through the brake adjuster access hole.
One small diameter blade screwdriver can be used to push the self adjuster lever away from the notched adjuster nut, while a second flat bladed tool is used to lever the adjuster nut, rotating it so as to back off brake shoe expander adjustment.
Jun 16, 2009 | 1997 Ford Escort
Removing rear break drum from a 2006 chevy Equinox
Apr 07, 2009 | 2006 Chevrolet Equinox
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Dryers Logo
24 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
