Question about Daewoo Washing Machines
How I Check drain pump for daewoo washer - Daewoo Washing Machines
    Master:
  • Daewoo Master
  • 683 Answers
Remove it and check for anything that is jamming it if good u can make up a lead to test and see if it runs
Posted on Apr 22, 2019
SOURCE:
My dwd m 12c6 daewoo washing machine will not spin
Blocked drain pump and or drain outlet hose. Check the inside of the pump as well. Daewoo are common to get coins etc stuck in the tub to pump hose and foreign material stuck around the impellor in the pump. If it cant pump out, it wont spin.
Jan 05, 2015 | Daewoo Washing Machines
IE error code
Water inlet error - washing machine failed to fill
The fault code is displayed, if the washing machine does not detect any incoming water.
·Check wiring to water inlet valve
·Check water valve
·Check drain pump
·Check pressure switch
Check PCB
Oct 05, 2014 | Daewoo DWDWD3011WW Front Load Washer
Water won't drain
You can lay the hose to get water out put in bucket dump out than with it empty turn water off and start see if the pump start the pump down. It can be pump or the idems in washer blocking some water getting out and the timer could be gone check severl setting and see if that it.
Aug 12, 2014 | Daewoo DWDWD3011WW Front Load Washer
My Daewoo does not want to spin, any suggestions?
first does all of the water pump out when wash cycle is done? if not then check your drain lines and see if pump is coming on. if it is not then it wont let the washer spin,
Jun 03, 2014 | Daewoo Washing Machines
Daewoo washer DWF 800WPS water drains before wash
Make sure the drain hose is about 1 metre high from ground. If drain hose is lower the water will keep draining.
May 27, 2013 | Washing Machines
Water wont pump out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 30, 2010 | Daewoo DW500M Top Load Washer
OE code on front load Daewoo washing machine
According to your owners manual you only have two choices...
Your lint screen is blocked or you have a problem with your drain motor (a separate device ).
Old age & experience will add a third... Assume lint did get past all those sophisticated "filters" and is presently residing inside the impeller housing... In the olden days when those housings came apart (aluminum/aluminium) I took out an entire sock and enough lint to make another... My guess today is you buy another plastic pump.
Sorry I could not get part number or price here in the USA...
Not even cleverly saying "spares" (but I did try).
Hope this was helpful.
Daewoo Washer Drain Pump Spares Yahoo Video Search Results
Yahoo Image Search Results Page
Amazon com Daewoo Dwd m301wp Mini Drum Washing Machine English Menu...
http://www.daewooelecusa.com/customer-service/service-centers
Jan 06, 2010 | Daewoo DW500M Top Load Washer
I bought a Daewoo washer and dryer set just over a year ago and we have replaced the pump on the washer already, the dryer takes longer to dry than my old one and the washer does not wash and never has...
The problem with the drain pump is that items get stuck in them. That is the reason for the filter which needs to be cleaned occasionally. It is a very easy job to remove the pump via the bottom of the machine and clean out the pump. I had a coin stuck in there and a toothpick. After cleaning out the pump the machine ran perfectly.
I like the machine, it does a good job and has a lot of neat settings.
Nov 18, 2009 | Daewoo Washing Machines
Daewoo Top loader washing machine water wont drain...
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Nov 11, 2008 | Daewoo DW500M Top Load Washer
Oe code
I had the same problem. First the grinding noise during the rinse cycle and then after four weeks the OE code. LG had a local repair service come out and he determined that the drain pump was dead and ordered a replacement. Still waiting on part after only 3 days.
Dec 22, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Daewoo Washing Machines Experts
Marvin
Marvin
Fahr Quad
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
