Question about NEC MultiSync LCD1765 17" Flat Panel LCD Monitor
No Display On my NEC monitor, there is no display, the power light turns from amber to green when the PC is powered up, but no display....Evidently it is getting a signal from the PC video card. The onscreen menus do not show either.... I am unsure where to start here, what could be wrong, and is there a service manual available to tackle this??? Thanks for any help you can provide.... Don
  • donthetech Nov 27, 2007
    tonysmith,
    I tried the basics, the monitor is the problem, I just want to know where to look next, inverter, backlight, etc., and is there a service manual that has illustrations to distinguish the parts....
    Don
  • Anonymous Feb 26, 2009
    same
How do i factory reset my NEC LCD1712 Monitor?
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 22, 2014 | NEC LCD1712 17" Flat Panel LCD Monitor
My monitor no display and light is blinking
if the monitor light is blinking this suggests that, there is no display signal coming from the tower. This could be because of the following .
1. Bad video card 2. Bad video software
To check,where the problem is , power of the system tower and remove the power cord from the back of the tower. Press and hold the power buttoon for 10 seconds and the reconnect the power cord and turn the tower on. Check if there is any display or the status of the light changes from amber to green for even a small instance.
If the light changes to green and back to amber the video port on the tower is bad
Alternatively you can connect the monitor to another desktop or laptop to check if the same is working correctly.
Thanks for using fixya
Proton
Oct 13, 2012 | Computers & Internet
No sign of life from the display half but the bottom reads life.
If you have already checked the connections from the screen to the PC, check that you have a power light on the screen. (Green or Amber). If no light, check power to screen. If it is amber, then the screen is not getting a signal from the PC - recheck connections. I would suggest you try and connect the pc to a different monitor to check whether it is the screen or the PC.
If it is the same on another Monitor or if the power button is green on the screen, then the pc is not sending information properly. Turn the pc off manually by holding the power button on the bottom half for about 10 seconds. All lights should go off from it. Now turn it back on again and see what happens.
If you see loading windows and then goes black, do the following:
Turn off the pc (bottom half). Turn back on and as soon as you pressed the button to turn on, start tapping the F8 key until you come to "Windows Advanced options" screen. use the arrow keys and go to Enable VGA mode. Press the return key twice. If it loads to windows, then fine. If not, then you may have a problem with the display adapter.
Hope that helps
Nov 11, 2010 | Computers & Internet
The on/off of pc monitor (LCD) is blinking.
Most LCD monitor (depends on the brand) power indicator light will either turn from Green to Amber, or flashing Amber, or flashing green, when it does not detect video signal feeding it. So it may be normal with your monitor. Are you haivng problem with the display? If it displays he pictue OK then there is nothing to worry about.
Apr 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
I hooked my new computer up to my NEC Multisync 1700V moniter. When I power the moniter up the GREEN light comes on until I get a "no Signal Message" and then the amber lihgt comes on.
hi, hook up your old one and change the refresh rate to 60 or 70 hertz, go 2 display properties, then the settings tab, then advanced,then monitor. and set it as i said. turn off computer after you change settings. hook up the nec, you then should be good 2 go. good luck! and please rate this solution. if you need further help, reply.
Apr 13, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
When i turn on the pc as soon as the screen or desk top pops up it turns black.
try to boot in safe mode and reduce your screen resolution to 800x600
Apr 17, 2008 | Computers & Internet
Monitor doesnt come on , but the power light goes from amber to green. then comes on after 20-30mins maybe.
Maybe update your display drivers. PC appears to be slow.
Make sure you don't have a bunch of apps that auto start.
Do you hibenate your PC?
Same issue if you connect monitor to another PC?
If issue follows you to a different PC it says monitor. If it doesn't it says the first PC (that monitor is currently connected to) had a cpu/memory or a driver issue.
Good luck
Oct 25, 2017 | Sony SDM-HX93 19" LCD Monitor
NEC MultiSync LCD1765 17" Flat Panel LCD Monitor Logo
240 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
