Question about Philips Televison & Video
Philips smart TV 55pfs 8109 blink 2 times.
Show the logo and shut down. Due it twice and stay in stand by. The led begin blink twice. So it stay blinking 2 times continuesly. After reconnecting the power cable it start again two times with logo. How to fix it?
SOURCE:
ctf1800
  • 4402 Answers
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Posted on Feb 26, 2008
  • 138 Answers
SOURCE: philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Posted on Aug 19, 2008
SOURCE: philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Posted on Oct 06, 2008
ginko
  • 19396 Answers
SOURCE: Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
localwonder
  • 6784 Answers
SOURCE: TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Posted on Jun 21, 2009
Have grundig gu22dvd tv and can not get volume on the sky remote have tried the normal things and have code but still doesn't work
Try an auto search with the remote, you might have already tried it :
1. press tv
2. press select and the red button simultaneously untill the LED light flashes twice
3. Then keep pressing the TV and Standby buttons one after the other (not at same time) until the tv swithches off, then press select to store the code, the LED should flash twice to confirm this.
Once you have the remote working the TV, you can get the remote blink back the TV code so you can write it down for future reference.
  • Press the TV button on the Sky remote
  • Hold down Select and the Red buttons together for approximately two seconds until the LED blinks twice
  • Key in 9, 9, 0
  • Key in 1 on the numeric keypad and count the number of times the Red LED blinks. This is the 1st digit.
  • Repeat for 2 and 3
  • Note: no Blink = 0 (zero)
Sep 09, 2014 | Grundig GU22DVDPX 22 in. LCD TV
Philips 43p8341/37, ptv 914 chassis, led code blinks
Let's check and see if we can find the correct board with the problem. A good place to start is to disconnect the jumper jack 1516 [TV unplugged first]. Now plug in the TV, and power the TV on. If the tubes light up and shut down...then the small signal module is at fault. {this contains convergence ICs} Or it could possibly be the ssb [small signal board] is bad. Leave the set unplugged for a few days and plug in and power up this TV..It may work for a few seconds and go down again. These are two good places to start before you pull the boards out...and they are not easy!
Jan 23, 2010 | Televison & Video
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
TV turns on but turns itself off after short amounts of time
This set is equipped with LED diagnostics. Once it shuts down on the front of the set hold down the MENU and INPUT, (sometimes labeled DEVICE) buttons until the LED starts blinking a 2 blink sequence. For example one blink pause two blinks long pause and then repeats is the code for no problem. All of the fault codes begin with two blinks and then one through 4 blinks. I suspect that yours will be a 2 - 4 code because of loss of vertical sweep. Which is bad solder connections on the deflection yokes. A common problem with these units.
May 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Philips 42pf7321d/37 blinking power board question
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 50p8342 problem
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
LED Blinking
Okay 2 blinks isnt a error code, so your set isnt shutting down due to a protection issue, so I would suspect one of the low voltage regulator transistors or the horizontal output transistor as being defective
Jul 06, 2008 | Mitsubishi WS-55819 55" Rear Projection...
TV shuts itself off
Horizontal Out Transistor or Flyback Transformer seems bad. check n replace please.
Jun 08, 2008 | Sony KV-27S42 27" TV
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
