Question about The Video Cameras
I have the Cannon ES290. When I Put in a cassette, and push in, it does not go down. It set's there a few seconds then pops back out. Any quick fix?
    New Friend:
  • 31 Answers
Check for debris in the aperture. Check for anything sticking onto the cassette. Has anything fallen inside, any fluff, paper? Anything hanging off, any screws or fixtures loose?
Posted on May 19, 2019
SOURCE:
cpt100
  • 154 Answers
SOURCE: Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Posted on Mar 17, 2007
battlesmith
  • 382 Answers
SOURCE: Cassette Recorder play problem
Belts are prone to harden over time,the belt will be broken so replace it.. Also as you say the unit does turn off which is the problem of Take-up reel sensor ..Try to Take to any Service person and replace it,your player will be back in condition..Thank you..
Regards!!!...
Posted on Jul 24, 2008
SOURCE: shuts down after a few seconds
monitor come on for two seconds and them go blank
Posted on May 15, 2009
  • 484 Answers
SOURCE: gears not changing quickly enough.
Two things to this problem.
1. Clean your drivetrain REALLY, REALLY thoroughly with a good degreaser and a bristled brush. All of it. Clean the derailleurs, the chain, the cables. Once it is all cleaned up and dried off, lubricate the chain and the cables ONLY.
2. Shift your bike into the highest gear and release the cable. Pull it taut and re-tighten it. Flip it over and shift into your middle cassette cog while cranking the pedals. Use the barrel adjuster on your rear shifter to get the jockey wheel on the cassette aligned over the correct cog.
This was an abridged guide to rear derailleur adjustment because it sounds like it was more grunge in the cable or derailleur than anything else, but i'll check back and if this solution doesn't work out, i'll give you tips on a far more thorough overhaul. Just remember a clean drivetrain is a functional drivetrain, and the cables and chain are the only thing you are supposed to lube.
Hope this helps,
matt
Posted on Sep 16, 2009
SOURCE: Put tape in cassette compartment push it closed -
I am having this same problem and I did a test. There appears to be some type of light sensor that fits in the tape when you try to close it. When there is no tape the loading mechanisim will work. If you put in a tape it covers the sensor and will reject the tape. I used a clear straw and covered the sensor and it closed. I then blocked the ligh from coming in the straw and covered the sensor and it ejected the same as having the tape in. Does anyone know where I get get this part?
Posted on Feb 06, 2010
VHS stuck in Orion tv how do I get it out
https://www.howtomendit.com/answers.php?id=73308
Besides trying the upside down approach, try Sharon's tip at the very bottom of the link.
Quoting:
"I just had a tape stuck in a VCR/TV combo so went on the Internet for help and all other answers were to take the top off the VCR which of course is not possible with a tv combo.
While stuck the the power would turn on it would just emit a low moan-whining noise for a few seconds starting strong then running down and then power off. Couldn't watch TV in that state, it would automatically power off.
So I got down comfortable on the floor eye level with the input slot with the flapping door cover and pressed the power button then quickly with my fingers of one hand inserted them in the tape load slot and using my middle fingers continously began pushing up on the top edge of the cassette in a stiff but quick flicking motion over and over again (like trying to physically force the tape up with intermittent prodding short and quick strokes so it could clear the lip if the eject mechanism kicked in) while simultaneously pressing and holding the eject button with my other hand and after a few tries and 5 or six upward prods on the front top edge of the cassette the eject mechanism activated and spit out the tape.
Sharon
June 2007"
Oct 23, 2018 | Orion Televison & Video
How do I reset a Cannon Powershot sd1400is if it doesn't turn on?
Try taking the battery out and wait a few seconds and then put it back in.....make sure the battery is full. and Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
Thanks,
Satya
Jun 28, 2014 | Canon PowerShot SD1400 IS IXUS 130...
"add paper cassette"
Turn the printer off. Pull the paper cassette out and push down the green tab down to see if there is any paper jam inside. put the cassette back in and turn the printer on. Worked on my kyocera FS - 1370 DN.
Mar 16, 2012 | Kyocera FS-2000D Laser Printer
"remove cassette" warning on ZR100
I have read that slapping the non-foldout display side of the camera a few times has worked for several people.
Dec 06, 2008 | Canon ZR100 Mini DV Digital Camcorder
Panasonic NV GS 15 deck jammed
Yes i had the same problem ...
1.Put the cassette as far as it allows... and move the cassette left and right slightly twisting , and you will activate the mechanism
2.SOON the mechanism gets fully out immediately!!!! remove the battery
3.CLEAN contacts (I'm looking right now on the internet to find where the hell sensors-contacts are)
4.PREY that it works :-)
Feb 22, 2008 | Panasonic PV-GS2 Mini DV Digital Camcorder
Cassette will not load!
I have one doing the same thing. I called Cannon and the told me I would have to send it in for service. Now after reading that about 10 other folks having the same issue, I think Cannon has some issue with the ZR100.
Jun 22, 2007 | Canon ZR100 Mini DV Digital Camcorder
Mar 15, 2007 | Canon ZR60 Mini DV Digital Camcorder
Re-attach the power source followed by Reinsert Cassette
Hai Problem in mechanism. If the tape does not loaded completely, the message will show "Reattach the power source" Please check mechanism. Raghavendra, M/s.prathiksha Electronics
Jan 25, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
Video Cameras Logo
Top The Video Cameras Experts
Prudhvi Kumar
Level 1 Expert
D. E. Hev
Are you a The Video Camera Expert? Answer questions, earn points and help others
