Question about Amana Refrigerators
I need help programming my Amana refrigerator serial number AFI2538AES after I replaced the HV control board W10890094.
Hi - I just replaced the HV board W10890094 on my Amana refrigerator serial number AFI2538AES. When I plugged it back in I followed the directions for programming it. I got to the part where I am supposed to put the code in (1412) and the refrigerator temp buttons don't display numbers. They say H2O and ICE. There seems to be no way to enter the numbers. Any Help?
SOURCE:
peyton32034
  • 410 Answers
SOURCE: Control Board Programming Code
the code is most likely printed on your model number label located inside the refrig compartment and entering the code instructions are on your tech sheet that is taped to the underside of your refrig.
remove the toe grille and feel under the cabinet for a plastic bag/envelope taped to it. just follow the instr for entering the code..
ps if the code isnt on the model label it may be on the tech sheet..
Posted on Dec 19, 2007
  • 1314 Answers
SOURCE: Amana Temp Controls Stop Working - Show Dash - Food Spoiled
could be a glitch in the defrost cycle the adaptive defrost control could be faulty and when you unplugged it you might have reset it it should be ok till monday but i would just get the basics untill the tech looks at it
Posted on Jan 26, 2008
  • 265 Answers
SOURCE: Adobe InDesign CS2 serial number invalid
You may have purchased a pirated copy of the software. You need to contact Adobe, and they will help you to determine the validity of your software purchase, and get you a new serial number or re-activate your current one.
If you go to Adobe Customer Support: CLICK HERE
... you can select the pop-up which offers Live Chat Support. They are very thorough and very helpful.
Posted on May 30, 2008
i want to adobe indesign cs 2 and illustaor cs 2 serial numbers
Posted on Sep 12, 2009
  • 8081 Answers
SOURCE: TI89 Titanium--main board replaced,must get its serial number
I am not sure if the number on the case is the one required. The TI89 Titanium and other recent TI machines have a unique ID. To get it, turn the calculator ON, Press F1 select 3: About.
On the subsequent screen, one finds various bits of information among which is a product ID and a 14 digit hexadecimal number ID ( a number in base 16, with Arabic digits 0 to 9, plus and A, B,C,D,E, and F)
The same number can be revealed by TIConnect software:
After machine is recognized, click TI Device Info. The Device ID is returned under General Information Tab or ID list tab.
This device ID could be the one needed for the Calculus Made Esay. software
Posted on Dec 17, 2009
Maytag refrigerator mfi2568aes replaced control board in back and input code and saved. now nothing is running but display is fine
Sometimes the new board will be in defrost mode when you install it, leave it powered up for 30 minutes to see if it begins cooling... Maytag Refrigerator Control Board W10890094
Also be sure the code is entered properly, these will do NOTHING without the right code.
Jul 08, 2016 | Maytag Refrigerators
The control panel of my AFI2538AES is blinking and the ice flap opens and closes continually
The cause is a shorted control board and this unit will require a new one to function correctly part number W10310240 this is the number for the information you provided. Normally the run number is an issue but all 12 of the model numbers use this board. Good Luck
PS. Part name is Board-HV Control Iceland
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 20, 2014 | Amana AFI2538AES Stainless Steel (256 cu...
Refrigerator temperature control board
This is the part: http://www.appliancepartspros.com/whirlpool-cntrl-elec-w10890094-ap6027422.html
Its not cheap there is nothing about changing the board for that model.
Apr 18, 2017 | Maytag Refrigerators
The control panel on the door where I select ice or water will not let me select between ice or water. The lights are off on both and when I press either all of the other lights turn blue or red.
If you have no control at the dispenser, you will need to replace the HV control board. Here is the board to order.
Once you replace the board it will need to be programmed. The Program Code is located on the Serial Plate on this unit after the word Code.
Nov 08, 2012 | Whirlpool GI5FSAXVY Stainless Steel ...
Flashing control panel, ice/water not working, ice release flap constantly opening and shuting
Had the same problem and you need to replace the main circuit board on the back lower left of the refridgerator! Cost about $125.00 for the board and comes with instrutions!
Apr 22, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Maytag mbf2258hew replace jazz board
bug, the jazz board is pretty easy to replace. The light cover will slide off toward the back. Now if you look behind the control panel you will see two slots. Take a flat blade screw driver and push the cover tabs in while pulling down on the cover. The cover will come down. Two slats slide in on the front and will release, disconnect the harnesses and install the new board. Reverse the process. Catriver.
Sep 04, 2007 | Amana AFB2534DE Bottom Freezer French Door...
Refrigerators Logo
49 people viewed this question
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Carmen Mikulic
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
