Question about Kenmore Elite 45986 Front Load Washer
F-H code and water won't stop
Our washer stops on the rise cycle, beeps loudly with the error code F-H. It's hard to figure out how to get it to unfreeze. I've cancelled everything and can get it to then start on the "drain and spin" cycle to at least drain the water down, but I can see the water outlet in the door frame continuing to pour in water. Even when the cycle is through and it says "clothes clean", water doesn't stop. Earlier I went to check the status (no lights, cycle finished), and I opened the door and water poured out. What is happening? (Sears site has no Q&A for service support). Help!
  • 7 more comments
  • Anonymous Dec 31, 2007
    same problem
  • KyraDavila Jan 04, 2008
    I'm having the same problem...any solutions? Help please!!
  • Anonymous Jan 28, 2008
    We are having the same problem. Please help. The error will not go away and I must cancel the program and drain and spin tehe clothes.
  • Anonymous Feb 01, 2008
    Help!! I am having the same problem. Mine also flashes F/H and also gets stuck on the rinse cycle. I also have not been able to get the code off of the door open unless I reset everything and then drain. I too had water pour out the door and was such an mess!! I must say it's very upseting to spend the money and still have the mess, what's saving time about this????
    Please help..
  • Anonymous Feb 06, 2008
    same problem and no idea what to do
    I have the same problem. I found this site,I tried what they said, but my filter was not clogged. It's worht a shot to try though! Here's the link.
  • Anonymous Feb 07, 2008
    Same problem here, but completely intermittent. I have searched for "kenmore he4t FH" and found that it could be a pressure switch problem. this switch is not communicating with the CCU board to indicate enough water is in the tub. After reading all the blogs about how long and $$$ it is to get a sears repair person out, I am going to attempt to fix it myself, following the guidelines from the "Samurai Appliance site". He says a wiring harness may have come loose.
  • Anonymous May 05, 2008
    cleaned water inlet filter
    unplugged and re plugged
  • Anonymous Sep 15, 2008
    Thank you for the suggestion of the made my day a whole lot better...I have been fighting with my washer for weeks, and now I have fixed the problem with only a modicum of effort!!
  • 57 Answers
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Posted on Feb 16, 2008
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
Dec 12, 2013 | Fisher and Paykel Washing Machines
When tub drains beeps twice and won't continue
Hi - Does the drain pump make a humming noise as well? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if what pump out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite washer service code CLL SrU
Re: Kenmore Elite 417; error CLL SRV We have well water and I think my error message and locked door were because the machine was trying to plump water and not getting any. I heard the error beeping and sent to check it out. There was another noise that didn't stop even after unplugging the washer, although the beeping did, which finally stopped after I turned off the water valves. Press and Hold the power button down to unlock the door and retry. If you still have trouble, call for service.
Sep 25, 2012 | Washing Machines
Error message - PE.... on lg intello washer. my washer is full of clothes and won`t get to the cycle for rinsing .I press on auto-off , then start-pause . the light for water-level does not go on...
Is there a lot of water inside like more than normal? That is a pressure sensor error. Check pressure hose inside the washer. It is a small hose about 5/16" diameter connected to the tub and pressure switch. If there's a hole in it the air scape and the pressure switch will not turn off the water. The control board detects the problem and stop will show error code.
Nov 21, 2017 | Washing Machines
Whirlpool - MOD WTW 6600SW1 SER - CT 4270227 Type 580 For the past several weeks, the washer became progressively louder during the spin cycle and it sounded as if there was something rattling such as...
Sounds like you have change in the pump the coin may be stopping the propeller of the pump not allowing it to pump out the water. you may be able to take the pump off and clean the pump if the propeller is too bad you may need to replace the pump the pump part number is W10049390
Jul 15, 2011 | Whirlpool Washing Machines
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
Washer stops during middle of cycle and post 02 F
f 02 is the error code for taking too long to drain the water disconnect power remove 3 torex 20 screws from lower front panel revove cap from pump asm to check for any obstructions beware there will be water in the pump
Dec 15, 2008 | Whirlpool GHW9100L Front Load Washer
Washer won't stop beeping and can not change cycle selections
what light is flashing when it beeps. You might have to check and see if you are getting water to both Hot and Cold on the machine. Or your door might be closed all the way
Jul 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
251 people viewed this question
Sal De
 Brian Main
Brian Main
