Question about HP Officejet 4500 Wireless All-in-One Inkjet Printer with Copy/Fax/Print/
HP Officejet 4500 Model G510g ...First Paper Feed Gear Attached to DRIVE BELT. GEAR & SHAFT NO LONGER PROPERLY ALIGNED. gear was stripped on shaft then super glued. next step?.
SOURCE:
  • 92 Answers
SOURCE: Gear after the motor is stripped
yes it can
Posted on Aug 28, 2009
  • 55 Answers
SOURCE: My Hamilton Beach Food processor model # 702-1 has
my suggestion is that watever spare part u replace, get it replaced by the original manufacturer to avoid future problems. take it to the shop you have bought it from, ask them where u can get one. they may help u better with contacting the manufacturer. i know its time consuming! good luck!!
Posted on Oct 14, 2009
komguy
  • 2306 Answers
SOURCE: HP OfficeJet J6480 Feed gear assembly needed!
Check on www.partsurfer.hp.com it will tell you if the assembly is available, if not on HP site you will need a used unit to get parts from.
Posted on Jan 19, 2010
Testimonial: "No parts available unfortunately. "
canontech
  • 1219 Answers
SOURCE: Need paper feed gear for Minolta 1250W printer
Try to find the local minolta service and try to order over them. Or go in few printer repair shops and try to find similar one.
Where are you located?
Posted on Jul 07, 2010
  • 65 Answers
SOURCE: How do you remove pinion gear attached to motor shaft?
with gear puller or press,sometime spring ring lock the gear on the shaft,remove it first
Posted on Nov 24, 2012
My officejet 4500 is making a horrible noise when it warms up
Where was the pen stuck? All the gears in that printer are plastic and therefore are subject to shearing off or stripping.
Jan 07, 2018 | HP Officejet 4500 G510G Inkjet...
Syma so33g lower blades do not rotate
wrong!!! if the bottom set of blades aren't turning its because the drive gear for that shaft is loose and is spinning on the shaft instead of spinning the shaft itself. try tightening the screws but make sure the screws are lined up with the holes in the shaft so they seat otherwise your going to strip the plastic gears threads. if that doesnt work then you will have to replace the gear and shaft. its a cheap part and readily available. only problem is youll have to take apart almost the entire heli to get the old one out n the new one in. the gear comes pre-mounted on the shaft. Buy 2 or 3 of them right away as you will have to replace it just about every time your heli tips over while the blades are turning. the screws only go into the shaft about a 16th of an inch and is easily stripped out
May 28, 2012 | SYMA Toys industrial Toys
Printer will not feed paper
Click here for instructions on how to resolve this issue.
May 26, 2010 | HP PSC 1210 All-In-One InkJet Printer
Jan 19, 2010 | Office Equipment & Supplies
Error message carriage jam and/or paper jam
Often a carriage jam is caused by a paper jam. If you're getting a carriage jam message and a paper jam message, this video should help.
utube.png You-Tube video "wPjahOY5CDo" placeholder
Nov 21, 2009 | HP Photosmart C6380 All-In-One InkJet...
HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Nov 03, 2009 | HP PSC 1350 All-In-One Thermal Printer
Won't feed paper
empty out thr paper supply, check the paper feed area for debris, blow out area with compressed air (Computer Duster), fan paper carefully and re install.
retest machine
Ed
May 04, 2009 | HP PSC 1610 All-In-One InkJet Printer
Noise when scanning document
Visually check the clutch spring (located on the left side of the pickup roller shaft, just before the gear). If the spring is deformed or broken, replace the entire pickup roller shaft. The part you need to order are shown below. You will also need a small 'C' clip. I do not know if the clip comes ith the shaft or the gear...
PA03360-Y110
Pick shaft
PA03360-Y112
Pick Bearing ‘M’
PA03360-Y107
Clutch
PA03360-Y106
Clutch Spring
PA03360-Y105
Pick Gear
Regards,
Eric F.
Jan 25, 2009 | Fujitsu ScanSnap Manager
Carriage jam continues after clearing paper
I just picked up an officejet 7410 off craig's list for free because it a had a carriage jam error. I followed all the online instructions to fix it and nothing worked. I tore the printer down to the guts and found a black plastic gear that had a cracked shoulder. This gear is pressed onto a metal shaft which is splined. The splines are to keep the gear from spinning on the shaft. The crack in the shoulder of the gear was allowing it to spin on the shaft which it was not supposed to. I'm assuming the gear cracked due to a paper jam. I fixed this by drilling a 1/16th diameter hole through the shoulder of the gear and the shaft while the gear was installed on the shaft. Then I installed a roll pin(or tension pin) into the drilled hole, thus keeping the gear from spinning on the shaft. Now it works great. One of the pics has a yellow mark where the crack is, with the pin installed 90 degrees to the crack. This requires a little skill, but I hope it helps.d921235.jpg0ad56a9.jpg
Aug 31, 2008 | HP Office Equipment & Supplies
HP Officejet 4500 Wireless All-in-One Inkjet Printer with Copy/Fax/Print/ Logo
Clive
Clive
Thomas F. Schneider
