Question about RCA F19426 19" TV
Burn up repeated
Mr. Pravin .ihave tv samsung model#tc9865tb. burn up resistor 1olm repeated right by flyback, when power on. power supply, horizontal output & vertical output ok.
2 Suggested Answers
  • 5138 Answers
SOURCE: Replaced Flyback Transformer and Horizontal Output Transistor
I am proud to see you got your set working Good job!
Posted on Aug 26, 2008
  • 647 Answers
SOURCE: I have two Sony KV-27FS120, they have the same
Check very carefully for cold solders on horiz. drive transformer also replace the electrolytic cap that shapes the horiz. drive signal - if you have a scope and manual compare the drive signal shape.
Some times using poor after market horiz o/p's also causes the problem - does the o/p heatsink get to hot to touch or does the horiz o/p blow immeadiatly?
Posted on Oct 19, 2009
Testimonial: "In my first post I said: No horizontal & vertical drive from IC001 jungle chip. And I say a little further: IC001 still have no drive output. I obviously checked with a scope. You suggest: with a scope compares the drive signal shape?? Something wrong with your analysis. Thank you anyway."
0 characters
1 Points
My tv is blinking 7 times repeatedly. (The red standby light) What does this idicate and what can be tried before I take it to a repair store?
The blinking standby LED usually is an error code - indicating possible overcurrent protection mode. It can be either a short-circuit in the power supply, the HT rail, or the horizontal output transistor(s) could be shorted along with the flyback transformer. Or it could be a combination of all of the above.
Assuming this is a model with a CRT, I doubt it would be the 'bulb' - it would most likely be a circuit failure. Check the flyback transformer, the horizontal transistors and the tuning capacitors in their collector circuit - one may be shot.
Check the power supply and HT thoroughly for shorts and open circuit components - burn marks on the board, dry solder joints etc. Look for obvious things first.
Once you are satisfied that one or more parts have shorted, and you don't wish to replace them yourself, submit the TV to a repair store and insist on a FREE quote - this way, you can then decide if you want to pay that estimate to fix it or not.
Feb 17, 2011 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Panasonic COLOR CT-27G14A
check Vertical IC out (LA78..) and resistor voltage supply from flyback transformer to this ic. Check the STR main power supply(and resistor near, change value), some times seems good out main board,but in operation not good
May 18, 2008 | Standard (CRT) Televisions
It won't turn on
The smell of something burning is not a good sign. The clicking sound you are hearing could be a relay or breaker kicking in and out as a result of whatever is wrong.
This could be cause by:
1. A problem in the power supply.
2. A problem with the Horizontal Output Stage.
3. The Flyback transformer.
Someone gave me a TV once that had the same problem. I determined that it had a bad flyback transformer. I replaced the transformer and the TV worked about 5 secs before I saw some black smoke come out of the new flyback. I turned it off right away and realized that something else was bad that caused the original flyback to burn up. The same thing was causing the new flyback to go as well. It turned out to be a shorted, 50 cent hi-speed switching diode. Fortunately, because I had turned the set off quickly when the 2nd flyback started to smoke, once I replaced the diode, the TV was fixed.
If you want to get it working again, you'll need to have it serviced.
Good luck,
- Jim
Jan 26, 2008 | Zenith B27A11Z 27" TV
No Power
you need to isolate the failure.
first, measure the voltage (called B+ usually) on the biggest elec. capacitor in the power supply. This should be about 130-160 Vdc.
If this isn't here, then the problem is in the power input circuit.
If there, then the high-voltage supply is down. If the set is anywhere near 10 years old, then replace the flyback transformer and its transistor (H.O.T.) and go from there.
The worst case is that a power surge or something has killed the TV's brain chip and you'll have to do a board replacement.
Let me know.
Jan 23, 2008 | Sony KV-35S26 35" TV
Toshiba vertical problem 36 inch
I dont realy know about this model but in many other model is a 1 oms resistror and is located around the flyback becouse the b+ for vertical output is taken from the flyback secondary voltage if these help you ....good luck and rate me
Jan 13, 2008 | Toshiba CZ36T31 36" TV
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Standard (CRT) Televisions
I see only horizontal line on TV Samsung CK-5339ZB
h/line is due to vertical section failure. 1 reduce brightness as you will get h/line due to vertical failure. 2 check v/section for loose contact or yoke connection. 3 check supply to vertical section. 4 check associated parts in v.section 5 at last check for vertical ic. resistor R410 CONNECTED TO high voltage transformator T444 is low value resistor. .5ohm to 10 ohm. it burnt again due to short cht in vertical mainly due to ic. hope this will help. as per schematic diagram go to
Oct 04, 2007 | Samsung TXN3271HF 32" TV
No power.
Usually, in those Sony sets, a crack developes on a small transformer in the horizontal drive circuit, which causes the horizontal output transistor to short. This immediately shorts out the switching transistors in the power supply and blows the Sony 0.1 ohm resistor fuse. A shorted flyback (high voltage) transformer will also have the same result. The power supply does NOT need to be replaced. The parts should be replaced, the flyback checked and the board resoldered by a qualified tech familiar with Sony sets.
Aug 23, 2007 | Sony KV-32V35 TV
Tv tube wont stay on
in 97 Sony had problems with Flyback on these sets, so the thing I would do different is change it, along with the other components
Aug 22, 2007 | Sony KV-32V42 32" TV
Need value for part R14109
R14109=750ohms 5% 1/4w (Resistor(750r5%.25W/R14109/179317) There is much more likely wrong with the TV. Resistor don't normally burn out with help, say, without a failing flyback transformer and possibly taking a transistor or two with it. If you need the manual, go to and type in "F31317" into the search field, you will several listings. If you decide to replace it yourself, here's some more part numbers in case you need them. Model: RCA\F25422TX41 Symptom: Dead Necessary parts: Transistor(Q14401) Main Voltage regulator Q14101 Resistor R14109 open. Research indicated the flyback transformer most probably bad \\CTC203AC4\HOT/D2578(Q14101/242224)* Flyback(14536119A/T14401/244229)* Main reg(P9NBSO/Q14101/244223) \Reg(MPS8599/Q14102/147665) Resistor(750r5%.25W/R14109/179317) Reg(MPSA06/Q14103/232218) Hope this helps you. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | RCA F31317 31" TV
RCA F19426 19" TV Logo
51 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
