Question about Panasonic PT-51HX41 51" Rear Projection Television
Where to buy feed resistors?
I have been trying to figure out a place to purchase the feed resistors for the STK's on my PT51HX41E. They are the 2.2 ohm units at R7048 etc. Worst case, what is the Panasonic Part #?
  • 934 Answers
Acme enterprises in Florida, inexpensive and very reputable...
or by phone at: 1-800-575-9833
Posted on Nov 27, 2007
I changed my two IC chips and three resistances on my Hitachi TV to fix color alignments. Now the problems is that yellow and blue double image are seen at the bottom of my screen with no much effect on...
Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
Apr 23, 2011 | Hitachi 43FDX01B TV
My TV is showing convergence symptoms: the screen looks like 3D effects and as if someone is pusing in the middle of the screen. I've replaced my STK's, 2 pico fuses on the G board, and tested each...
One of two things:
a) The STK chips you put in are no good (not uncommon)
If you weren't careful you may have removed a surface mount resistor accidently while desoldering the orignal STKs. I had a customer do that to me once and figured it out by comparing the board to the schematic for that board location.
Feb 19, 2011 | Sony KP-57WS500 57" Rear Projection...
I have a Panasonic Projection HDTV that i recently adopted. When i took it home I found a blue "bowing" at the bottom of the video. The experts i spoke to said i need to replace the convergence chips and...
The 2 STK convergence ICS are dead,all the resistors too,if it is smoking and glowing.Tries websites like, to buy a convergence kit to repair it again.Find the correct tv make and model.The convergence kit buy from one of these website's will have all the parts to repair it right this time.
Jul 16, 2010 | Panasonic PT-53TW53 53" Rear Projection...
JVC AV-48WP30 , how to change convergence
First of all tools,requirement to do the work on the Convergence board to do changes the 2 STK convergence ICS and some or all it resistors.U have a soldering iron,desoldering pump or soldering wicks and solders?Don't?must buy to do desoldering and soldering?Tries to buy solders.Tries wesites like to buy the convergence kit to replaced ur self,and buy the soldering iron here it have the desoldering pump attach to the sodering iron it self.For video tutoring how to take out convergence board out of the tv and replacing the 2 STK covergence ICS and some or all it resistors.Might included in the buying of the convergence kit,not,Try You Tube type in convergence problems,will have video some body doing it.
Jun 07, 2010 | JVC AV-48WP30 48" Rear Projection...
All letters and figures in the picture are duplicated with color
Ur tv have convergence problems,it dead.U must have soldering tools,solder and know how to do soldering to solved convergence problems.U must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like, to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 13, 2010 | Sony KP-51HW40 51" Rear Projection...
Unable to perform convergence.
Ur 2 STK convergence ICS,and some or all it resistors are dead.U must know how to solders?Replaced the 2 STK convergence ICS and some or all it resistors,will auto focus ur convergence back to normal buy itself.Tries websites like Tv repair, to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Mar 10, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
I phillips 60pp9202 red went out of focus so i replaced two Stk 392-120 with Stk 392-180 and two resistors, but now i have a bow effect please help
check resistors on convergence board for open ,check wiring and make sure cables were placed in right place then perform auto convergence
Jun 11, 2009 | Philips 60PP9202 60" Rear Projection...
Need to know what convergence chips are in Panasonic PT51HX41E
your model has two STK392-110 CONvergence Cs, you will also most likely need at least a few of the 2.2 ohm 2watt convergence resistors. I am posting a link to the actualrepair kit for your model which contains both Convergence ICs and all 6 of the convergence resistors and they send instructions with pictures that show how to do the repair.
May 28, 2009 | Televison & Video
Panasonic PT51HX41E Resistor values
you probly wont have to replace any resistors ,use STK392-180s.
Aug 27, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT51HX41E Colors are all messed up
You need to change the convergence ic's IC7001,IC7002 = part# STK392-110. Also check for any burnt or discolored resistors nearby. (about a $350 - $500 repair)
Aug 20, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
216 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
