Question about HP Compaq Presario V2000 Notebook
Compact presarion v2000 purchased march 06
I have this computer and when I tried to turn it on all I get when I push the button is 3 flashes from the lightning bolt on the front of the computer. Help
  • 51 Answers
Re: compact presarion v2000 purchased march 06
It looks like the battery has run out and there is no "juice". If this is connected to an AC adapter, then it means that there is no power being conducted.
Therefore, there might be a problem with the wall receptacle or the power supply.
Kindly leave a rating and I hope this helps :)
Posted on Nov 27, 2007
0 characters
3 Points
I want to download audio output driver of windows vista for compact presario2000
There are 3 models of hp that starts with Compaq Presario V2000 PC Notebook, they are
» Compaq Presario V2000 CTO Notebook PC
» Compaq Presario V2000T CTO Notebook PC
» Compaq Presario V2000Z CTO Notebook PC
Go to the below link and select your laptop model from the 3
Click the correct link of your computer, in the next page select dyour operating system that is windows vista, if there is no vista there then the driver for vista is not released by hp,if i am right there are drivers for 2nd and 3rd but not the first.
After selecting the operating system click next and select the link to driver-audio and click download
Jun 25, 2010 | HP Compaq Presario V2000 Notebook
My V2000 won't boot. It starts to power up, beeps twice stops at the Compact sign in the middle and "press [esc] to change boot order, press [F10] to setup, press [F12] to boot from lan" at the bottom....
probably keyboard connector is loose so, no imput from keyboard is coming in so it halts bootup. please check the connector [opening of a computer is requied probably]
Oct 30, 2009 | HP Compaq Presario V2000 Notebook
Presario V2000
Try uninstalling the RAM memory for a minute or two and start the machine with no memory, then reinstall the memory and start again, it should boot right up.
Jul 02, 2008 | HP Compaq Presario V2000 Notebook
Compact Presario v2000 the screen is blank
Remove the power cord. Remove the battery. Hold in the power button for up to 60 seconds to discharge the laptop. Try booting it.
Apr 27, 2008 | HP Compaq Presario V2000 Notebook
Laptop notebook
Your battery may be drained .
Turn off remove ur battery and switch it to ac power and start again .
If its ok insert battery and charge it.
Good Luck
Dont for get to vote. Merry Christmas
Dec 06, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 "Doesn't turn ON"
1) Unplug the laptop. 2) Press and hold down the standby switch under the lid in the upper left hand side of the laptop while pressing down the power key. You should have full power startup now. Let me know if it worked..
Jan 27, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
100 people viewed this question
Top HP PC Laptops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a HP PC Laptop Expert? Answer questions, earn points and help others
