Question about Zenith Televison & Video
Code for zenith digital converter box? - Zenith Televison & Video
SOURCE:
SOURCE: ZENEITH DTT900 ANALOG TO DIGITAL CONVERTER BOX CONNECTIONS
Can't go through the VCR in the normal way. The DTV box must be tuned to the channel you want to record and left there. Cannot tell VCR to tape one channel and watch another nor tape multiple timed and multiple channel shows unless the DTV is tuned to that specific channel. This makes most VSR functions useless.
Posted on May 28, 2008
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
SOURCE: CODES FOR ZENITH DTT900 DIGITAL TV CONVERTER
Hold Power and press Channel Up or Down. There are 150 manufacturers, so if you don't get functionality within 150 presses in one direction, you're SOL.
Posted on Mar 02, 2009
andy4254
  • 226 Answers
SOURCE: Zenith mbr3447 code for magnavox converter box?
To download the full code list with the instructions on how to program go to link below:
http://www.replacementremotes.com/store/productdetailp.cfm?productid=61978&reset=1
if your none of the codes work for you cable box then your SOL. try programming your cable box remote for your tv instread.
Posted on Apr 23, 2009
  • 144 Answers
SOURCE: Remote control code for an APEX digital converter
If that code is not listed in the little booklet that comes with the remote control then it's probably not capable or controlling the APEX converter. Most of the universal remotes can't accommodate digital converter boxes. The only possibility is doing a search for the code manually as instructed in the booklet. I suspect you won't find anything that will help you out except getting the original control from the Manufacturer or replacing the entire box and you will get a new remote control with it.
This is a problem I have run into before, the universal remotes people just don't have access to the digital converter codes. They are proprietary and vary from model to model and brand.
Zashiban
Posted on Jun 04, 2010
Ineed a code for tv converter box,What would the code be for a tv converter box ?
Different brand converter box will have differen tset-up codes. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Jan 11, 2017 | Televison & Video
How do I program a Toshiba remote to a zenith converter box
Signal converter boxes are pretty easy to set up - ABC News
abcnews.go.com/Technology/AheadoftheCurve/story?id=5485537
Digital Switch: How to Set Up Your Converter Box. ... If you subscribe to cable, satellite or some other pay-TV service, you'll continue to receive programming. ... aToshiba TV in my kitchen: Magnavox's TB100MW9 and Zenith's DTT901. The boxes are simple enough to set up, though I prefer the Zenith's remote control and ...
Comcast Remote Codes ' Program Your Remote Control
https://customer.xfinity.com/remotes/
Help and support with your XFINITY® Remote, select your remote control type and get the support you need to enjoy your XFINITY® TV!
Zenith remote control code list - channel recovery morning ...
www.thompsontv.com/zcodes.html
Dec 15, 2015 | Zenith Televison & Video
What is the code to program a Zenith digital converter box?
If you have a recent GE remote, it may have a code for your Zenith STB. The code list included in the package with the remote may include it. In any event, you can use the code search feature of the remote to find a code that will work. if you search through all codes stored in the remote without success, you may have to try another universal remote. All universal remotes do not contain all possible codes.
Sep 12, 2015 | Zenith 3-Device Universal Remote Easy To...
Where can I download a schematic for a Zenith dtt901 converter
Try the manufacturer's website and/or do a Google search using
" Zenith dtt901 manual pdf
Nov 08, 2014 | Zenith Dtt901 Digital Tv Tuner Converter...
Need the code zenith dtt 901
What code, I do not understand your problem. Please go into more detail. I have two Zenith DTT 901 converter boxes, each is on a 15" Sony TV. They work perfectly after I corrected a wrong setting on the menu.
Jun 17, 2010 | Zenith Analog to Digital Audio Converter
I need codes for my one for all urc-3021 for an apex digital converter box and a zenith tv
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Zenith TV's are: 0017, 0463, 0178, & 0092.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I do not see a listing for an Apex digital converter box in the Urc-3021 Code List.
But don't give up; many manufacturer's re-use other's control codes.
Therefore, I recommend using the One For All URC-3021 Code Search feature to find the compatible codes to control your device.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
Mar 01, 2010 | One For All URC-3021 Remote Control
Trying to control Zenith DTT900 box with Yamaha RX-V463 remote
Since Insignia and LG share compatible codes for digital-to-analog converters, review your remote control's manual for LG VCR codes as they should work to control the Insignia converter.
Feb 26, 2010 | Yamaha RX-V463 Receiver
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Universal remote programming
Since Insignia is really Zenith, a universal remote that can work on Zeniths should do the job. I have this converter box and use a RCA universal remote. I code that works is usually reserved for Zenith satellite boxes (5203).
Oct 26, 2008 | Insignia Digital-to-Analog Converter for...
I am trying to find a universal remote code to control the new Zenith digital tv tuner converter box. The model # is DTT900. It is for a person with low vision who cannot see the buttons on the remote...
Pls post back with the brand and model of the universal (replacement) Remote Control or what remote control you would want to use with the Zenith DTT900 Digital-to-Analog Converter Box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 23, 2008 | Televison & Video
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
