I AM HAPPY WITH THIS Radio. I try to link my iPhone but could not do it . now since then I can increase voice if on FM Radio But on AM I cannot increase violin Please Help and Advice
SOURCE: better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is
really bad (such as in a valley) the antenna would just amplify the
noise as well. Look for web based radio in this case or if you have
cable there are stations on it.
Jeff
SOURCE: The Disney Hanna Montana FM Microphone
The radio needs to be set to a specific station (its listed on the packaging) What the microphone essentially does is override the broadcast on that frequency and allows you to hear yourself. Its the same principal as the '80's classic "Mr. Microphone".
SOURCE: FM radio tune with fm antenna on a305-s6857
go to sound options.. dissable built in mic and enable fm radio. make sure antenna is plugged in
SOURCE: 1989 Chevy Truck , Stock Radio , Whining noise
Sounds like you have a capacitor problem.It could be a number of issues , but i suggest you check the alternator one first.
If you unplug the power cable to the back of the alternator and the whining goes away then replace the capacitor(usually only one bolt/screw)and you should be OK.
If not I sometimes have dissconnected the + wire from the HT coil when the car is running and the same applies,and if this works replace the capacitor or fit one if there isn't.
If none of this helps fit one to the + wires of your radio.
Please leave fair comment if I have helped you.
Thank you
Testimonial: "This is Great Info, I'll try all ideas . Ross "
