Question about DVD & Blu-Ray Players
Jensen uv8 does it matter if the safety brake feature is installed. and if not any other suggestions to bypass the dvd safety feature
    New Friend:
  • 53 Answers
Re: jensen uv8
Yes, most of them have a factory bypass that you can enable, though this is illegal because you can not legally have a movie in front of you while you are driving. There are people that will insert the code for you for about $50, or you can find the code and do it yourself. I was able to disable it myself on my Jensen.
Posted on Nov 27, 2007
0 characters
3 Points
Jensen Phase Linear uv10 dvd wont play while driving
When You installed it the pink wire that said to brake did you put it to an actual ground instead of the barking brake?
Jan 03, 2010 | Jensen DVD & Blu-Ray Players
Difficulties in installin of VM9311TS
just by pass it with the bypass code
May 04, 2009 | Audiovox VM9311TS
Parking Break Override
Simple if you don't know where to ground the wire to, just ground it with the ground wire of the radio. Twist the pink and black wires together, then put them with the black ground comming from the car. Hope this helps.
Jan 12, 2009 | Audiovox DVD & Blu-Ray Players
How do i bypass parkingbreak for a jensen 9311ts on mustang 99
take the parking brake wire should be pink or some funky color and hook it up to a +12 power source.
that way there is no need to use the e brake or anything for it to work
But as a word of caution all this is illegal in most states due to people not keeping their eyes on the road. ive read of people getting tickets for having disabled this security feature on their stereos. some insurance companys will not cover you if there's an accident you are involved in and you by-passed the safety feature. so before you do it, be sure to read your local laws and check with your insurance agent before doing it. you will not be happy finding things out the hard way.
Dec 02, 2008 | Audiovox VM9311TS
Need to by pass
There are two ways of bypassing the brake sensor in a Phase Linear UV8:
1. ground the pink wire using a toggle switch;
2. Use the unit's built-in bypass software.
a. Select "Tuner" mode (AM/FM);
b. Press the "Setup" button;
c. With the use of the remote, press 5, 4, 3, 2, 1, and then press and hold 0 for a couple of seconds or until the menu changes. d. d. Display should show hidden menu. Among the options would be to turn ON the "Brake override";
e. Press th "X" on the bottom leftmost corner.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | DVD & Blu-Ray Players
Phase linear uv8=jensen brake bypass code
from remote setup, 5 4 3 2 1 0(hold "0" for 4 seconds) let go. look for the brake override option and turn it on.
Nov 16, 2007 | DVD & Blu-Ray Players
DVD & Blu-Ray Players Logo
63 people viewed this question
Top DVD & Blu-Ray Players Experts
Are you a DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
