Question about Gigabyte Computers & Internet
Gigabyte GA-F2A55M-S1 schematic
I'm working on it guys give me.. schematic Gigabyte GA-F2A55M-S1 mb..
SOURCE:
nyilasrobert
  • 627 Answers
SOURCE: Gigabyte GA-945P-S3
1. 4 DDR II DIMM memory slots (supports up to 4GB memory)
2. Supports 1.8V DDR II DIMM
2. Supports dual channel DDR II 667/533/400 DIMM
Posted on Jul 17, 2009
rasengan79
  • 138 Answers
SOURCE: gigabyte ga-8i915pm
You can download the manual here
Posted on Sep 27, 2009
  • 2679 Answers
SOURCE: do you have a schematic diagram of the Gigabyte
http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=1417
Posted on Feb 14, 2010
Testimonial: "many many thanks juyruyrfiujh"
RescueTechLA
  • 2653 Answers
SOURCE: driver GIGABYTE GA-60X REV;1.0...
Everything you need is HERE.
Posted on Aug 14, 2010
Geekman
  • 32281 Answers
SOURCE: how to change bios setting on GA-F2A55M-DS2 motherboard to install XP
The BIOS should not prevent you from installing Windows XP.
If your hard disk is a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Posted on Feb 25, 2013
F2A55M-DS2 vista display drivers
Try downloading the latest drivers from AMD's website, found here:
http://support.amd.com/en-us/download
You can use AMD's auto detect program to find the best match.
If you're using a video card plugged into the PCI-E slot to display your graphics, I'd recommend disabling the onboard video by accessing your computers BIOS/EFI by pressing the right Function key on startup. If the graphics card you're using is AMD, the above link will also find the correct driver to use with it.
If it's a Nvidia based card, try their site for drivers, located here:
http://www.nvidia.ca/Download/index.aspx
Hope this helps!
Aug 23, 2014 | Gigabyte GA-F2A55M-DS2 Micro ATX AMD...
My fm2 a55 gegabyte motherboard is already a shutdown problem...huw to fix this?
specifite better the problem when it shut down? do you sw on and staying closed? clossing when you press sw on? Explane us to help you ok?
Jun 19, 2014 | Gigabyte Technology, Inc. Ultra Durable 4...
How to fix loud whine from gigabyte ga-f2a55m motherboard
This particular main board doesn't have the video integrated into the mobo, so it's got a video card. Often the video card has a fan. The fan could be causing the noise. Have you tried briefly unplugging the processor fan to see if the noise stops?
Apr 23, 2014 | Gigabyte GA-F2A55M-DS2 Micro ATX AMD...
My Gigabyte Mother Board shows some time Load Optimized Defaults then boot / Load Optimized Defaults then reboot / enter BIOS. How to fix it?
Two things come to mind first. Number one would be making sure you have the most up to date bios. Number two would be that maybe the motherboard battery is dying/dead and isn't holding enough charge to after being shut down to save the option you selected.
Apr 11, 2014 | Gigabyte Technology Gigabyte GA-H61M-S1...
Ga-81865gme not start with push botton power
Motherboard schematic are not available due to trade secret from the manufacture.. Motherboard are not made to be repaired because they are printed circuit in different layers.
Mar 29, 2012 | Gigabyte GA-8I845GVM-RZ Motherboard
I have a Gigabyte G31M-ES2L mainboard. I cannot get front panel jack to work.
Download the manual from Gigabytes site and refer to the schematic of the board that will show you how to place the jumpers on the correct pins
Dec 25, 2010 | Gigabyte GA-G31M-ES2L Motherboard
Schemat audio front panel conekt
Here is the link for the manual. It will show the jumpers and pins for sending to the back and front. USB, sound, etc.
http://english.gigabyte.ru/products/mb/manual/ga-ma69vm-s2_10.html
Good Luck
Dec 17, 2009 | Gigabyte GA-MA69VM-S2 (rev. 1.0)...
Computers & Internet Logo
Top Gigabyte Computers & Internet Experts
Alun Cox
Thomas F. Schneider
PNiss
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
