Question about Rockford Fosgate P3001 Car Audio Amplifier
Fuse my amp keeps blowing a fuse
    New Friend:
  • 53 Answers
Seems to me like there is a short somewhere, check all of your wiring. If it is still blowing fuses when it is wired so that all it has is power and ground, then you have something shorting internally, most likely a capacitor.
Posted on Nov 27, 2007
Will it hurt to replace the 20 amp fuse in my cigarette liter to a 25 amp it keeps blowing fuses
I am wondering if the fuse blows instantly or whether it lasts a while?
Fuse ratings for cars are usually mean or average values so a 20 amp fuse needs roughly 40 amps to cause it to instantly fail. I have not heard of a cigarette lighter needing that much current so I guess there is a fault that should be located and cured before you have a fire.
Maybe it is the element that is faulty...
I think fitting a 25 amp fuse would be slightly foolish...
May 12, 2017 | Cars & Trucks
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
30 amp starter fuse keeps blowing on 98 cherokee
you may have a short (verify the integrity of the insulation of the positive wire from that fuse going to the rear window defroster, check the relay & switch.) try to replace the relay.
Oct 03, 2015 | Cars & Trucks
Fuse keeps blowing
Once a fuse blows & you replace it-- ONE Time--
then you stop
You go to wiring diagrams of the circuit with the
blown fuse & start your testing
Aug 11, 2014 | 1994 GMC Sonoma
Keep blowing a 350 amp fuse
check your battery cables for corrosion
Sep 03, 2012 | 2010 Renault Laguna dCi
What causes fuse #5c in my 1996 buick park ave. to keep blowing?
A fuse that keeps blowing is probably the result of a wire that is grounded unintentionally. This would be the result of an exposed power wire touching the engine or body and grounding out. This would cause an excessive power draw and blow the fuse. The other option is that the fuse was lower amps than the original one. check the fuse diagram to see if the amps match up.
May 29, 2012 | Buick Park Avenue Cars & Trucks
All the lights work except the dash lights. The 5 amp fuses keep blowing and if I put a 15 amp it doesnt blow but no dash lights
DASH HAS A SHORT CIRCUIT.DASH NEED REPLACING BUT CHECK FOR SHORTS IN THE WIRES TO DASH.DONT PUT A LARGER AMP FUSE IN A CIRCUIT TO KEEP FROM BLOWING FUSE BECAUSE IF FUSE DONT BLOW WIRES GET HOT IN THE CIRCUIT THAT HAS A SHORT IN IT AND CAUSE A CAR FIRE.
Nov 04, 2010 | 1992 Ford Thunderbird
2009 e250 keeps blowing 10 amp parking fuse then
if it keeps blowing the fuse you have a short in the wiring
Sep 11, 2009 | 2009 Ford Econoline Cargo
Chevy silverado keeps blowing fuses
Your 20 amp fuse will not blow if glowplug wire shorts. each plug draws 15 amps which is 120 amps total.I think there are in line fuses for them. Try to wring out where each output from the fuse goes, disconnect all and reconnect one at a time till it blows.That should point to your problem process of illumination! Good Luck!!
Aug 25, 2017 | 1994 Chevrolet K1500
Keeps blowing fuses!!!
HI ..PUT AN AMP METER IN LINE TO SEE WHAT THE AMP IS DRAWING..WHEN IT IS CRANKED UP ..IS 20 AMP WHAT IT CALL FOR ON THE AMP IF SO I WOULD NOT GO ANY HIGHER.....BUT IF YOU HAD JUST USED 20 AS A STARTING POINT FOR AN AMP-AGE...SOMETIMES IT IS BETTER THAT THE FUSES BLOW ONCE IN AWHILE THAN THE AMP...ALSO CHECK FOR A LOOSE GROUND.....GOOD LUCK
Jan 29, 2009 | Planet Audio VX2002 Car Audio Amplifier
Rockford Fosgate P3001 Car Audio Amplifier Logo
98 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
